查看: 12596|回复: 2
在enWin窗口中添加按键
发表于 2015-4-8 15:33:23 | 显示全部楼层 |阅读模式
火哥,不好意思,还要打搅你,我在装载了uCOS-III系统使用emWin先创建一个窗口(是使用WM_CreateWindowAsChild()创建的),然后再向这窗口中添加四个按键,为什么按键显示不出来的呢????代码如下,请问是什么问题呢???谢谢!
        BUTTON_SetDefaultSkin(BUTTON_SKIN_FLEX);
        Buttom_Status = WM_CreateWindowAsChild(
        0,                                //窗口位置、大小
        200,
        320,
        40,
        WM_HBKWIN,  |WM_CF_SHOW|WM_CF_FGND, _cbStatusWin, 0
        hButton = BUTTON_CreateEx(0, 200, 80, 40, Buttom_Status, WM_CF_SHOW,0,GUI_ID_BUTTON0);
        BUTTON_SetText(hButton,"Machine");
        hButton_1 = BUTTON_CreateEx(80, 200, 80, 40, Buttom_Status, WM_CF_SHOW,0,GUI_ID_BUTTON1);
        BUTTON_SetText(hButton_1, "Relative");
        hButton_2 = BUTTON_CreateEx(160, 200, 80, 40, Buttom_Status, WM_CF_SHOW,0,GUI_ID_BUTTON2);
        BUTTON_SetText(hButton_2, "Absolute");
        hButton_3 = BUTTON_CreateEx(240, 200, 80, 40, Buttom_Status, WM_CF_SHOW,0,GUI_ID_BUTTON3);
        BUTTON_SetText(hButton_3, "Setup");
 楼主| 发表于 2015-4-9 12:16:09 | 显示全部楼层
火哥,我用emWin在窗口装按键的显示问题弄了很久都无法显示,请问是不是有什么设置的???我的另一个代码如下,麻烦火哥能在百忙之中给点提醒啊,谢谢了!!!
static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
    { FRAMEWIN_CreateIndirect,  "armfly",            0,                       0,  160,  320,80,FRAMEWIN_CF_MOVEABLE,0},
    { BUTTON_CreateIndirect,    "BUTTON0",           GUI_ID_BUTTON0,          20, 200,80,40, 0,0},
    { BUTTON_CreateIndirect,    "BUTTON1",           GUI_ID_BUTTON1,          120,200,80,40, 0,0}
void PaintDialog(WM_MESSAGE * pMsg)
    WM_HWIN hWin = pMsg->hWin;
        GUI_SetBkColor(GUI_RED);
        GUI_Clear();
//回调函数
void _cbCallback(WM_MESSAGE * pMsg)
    int NCode, Id;
    switch (pMsg->MsgId)
        case WM_PAINT:
            PaintDialog(pMsg);
            break;
        case WM_KEY:
            switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key)
                case GUI_KEY_ESCAPE:
                    GUI_EndDialog(hWin, 1);
                    break;
                case GUI_KEY_ENTER:
                    GUI_EndDialog(hWin, 0);
                    break;
            break;
        default:
            WM_DefaultProc(pMsg);
void Set_Background(void)
        WM_SetDesktopColor(GUI_RED);      /* Automacally update desktop window */
            WM_SetCreateFlags(WM_CF_MEMDEV);
        WM_EnableMemdev(WM_HBKWIN);
//开始创建窗口函数(用于包含两个按键)
        GUI_ExecDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbCallback, 0, 0, 0);
拜托了,万分感谢!!!
 楼主| 发表于 2015-4-9 15:55:11 | 显示全部楼层
问题解决了,其实,是关于坐标问题,当小部件放到新建的窗口时,坐标是依据新窗口而言的。
GMT+8, 2024-11-28 06:42 , Processed in 0.032212 second(s), 23 queries , Gzip On.
