查看: 21322|回复: 2
液晶触摸
发表于 2015-4-12 15:34:03 | 显示全部楼层 |阅读模式
为什么触摸矫正一直循环下去
int Touch_Calibrate(void)
        #if 1
        uint8_t i;
        u16 test_x=0,test_y=0;
        u16 gap_x=0,gap_y=0;
        Coordinate * Ptr;
        for(i=0;i<4;i++)
                LCD_Clear(0,0,320,240,BACKGROUD);
                LCD_DispStr(110,110,(uint8_t *)"Touch Calibrate....",RED);
                LCD_DispNum(150,90,i+1,RED);
                Delay_SysTick(500000);
                DrawCross(DisplaySample.x,DisplaySample.y);
                do
                                         Ptr=Read_2046_2();
                 while( Ptr == (void*)0 );
        ScreenSample.x= Ptr->x;
        ScreenSample.y= Ptr->y;
        Cal_Touch_Para(&DisplaySample[0],&ScreenSample[0],&touch_para);
        test_x=((touch_para.An*ScreenSample[3].x) \
               +(touch_para.Bn*ScreenSample[3].y) \
               +touch_para.Cn)/touch_para.Divider;
        test_y=((touch_para.Dn*ScreenSample[3].x) \
               +(touch_para.En*ScreenSample[3].x) \
               +touch_para.Fn)/touch_para.Divider;
        gap_x =(test_x>DisplaySample[3].x)?(test_x-DisplaySample[3].x)DisplaySample[3].x-test_x);
        gap_y =(test_y>DisplaySample[3].y)?(test_y-DisplaySample[3].y)DisplaySample[3].y-test_y);
        LCD_Clear(0, 0, 320, 240, BACKGROUD);
        if((gap_x>10)||(gap_y>10))
      LCD_DispStr(100, 100, (uint8_t *)"Calibrate fail", RED);
      LCD_DispStr(100, 120, (uint8_t *)"try again", RED);
      Delay_SysTick(2000);
      return 1;
                aa1 = (touch_para.An*1.0)/touch_para.Divider;
    bb1 = (touch_para.Bn*1.0)/touch_para.Divider;
    cc1 = (touch_para.Cn*1.0)/touch_para.Divider;
    aa2 = (touch_para.Dn*1.0)/touch_para.Divider;
    bb2 = (touch_para.En*1.0)/touch_para.Divider;
    cc2 = (touch_para.Fn*1.0)/touch_para.Divider;
                #elif 0
                aa1=0.088370;
    bb1=-0.000468;
    cc1=-24.042172;
    aa2=0.0001891;
    bb2=0.062395;
    cc2=-10.223455;
                #endif
                LCD_DispStr(100,100,(uint8_t *) "Calibrate Succeed",RED);
                Delay_SysTick(1000);
                return 0;
Coordinate *Read_2046_2(void)
    static Coordinate  screen2;
    int TP_X[1],TP_Y[1];
    uint8_t count=0;
    int buffer[2][10]={{0},{0}};  /*×&#248;±êXoíY&#189;&#248;DD&#182;à′&#206;2é&#209;ù*/
    int min_x,max_x;
    int min_y,max_y;
    int        i=0;
    do
    {                /* &#209;-&#187;·2é&#209;ù10′&#206; */
        Touch_GetAdXY(TP_X,TP_Y);
        buffer[0][count]=TP_X[0];
        buffer[1][count]=TP_Y[0];
        count++;
    while(!INT_IN_2046&& count<10);
    if(INT_IN_2046)
        touch_flag = 0;
    if(count ==10)
        max_x=min_x=buffer[0][0];
        max_y=min_y=buffer[1][0];
        for(i=1; i<10; i++)
            if(buffer[0]<min_x)
                min_x=buffer[0];
            if(buffer[0]>max_x)
                max_x = buffer[0];
        for(i=1; i<10; i++)
            if(buffer[1]<min_y)
                min_y=buffer[1];
            if(buffer[1]>max_y)
                max_y = buffer[1];
        screen2.x=(buffer[0][0]+buffer[0][1]+buffer[0][2]+buffer[0][3]+buffer[0][4]+buffer[0][5]+buffer[0][6]+buffer[0][7]+buffer[0][8]+buffer[0][9]-min_x-max_x)>>3;
        screen2.y=(buffer[1][0]+buffer[1][1]+buffer[1][2]+buffer[1][3]+buffer[1][4]+buffer[1][5]+buffer[1][6]+buffer[1][7]+buffer[1][8]+buffer[1][9]-min_y-max_y)>>3;
        return &screen2;
    return 0;
发表于 2015-4-12 18:51:34 | 显示全部楼层
楼主贴出来的代码跟例程的应该是一样的吧??
触摸矫正一直循环下去??请问校准完第四个点后液晶界面是什么??
 楼主| 发表于 2015-4-12 21:55:25 | 显示全部楼层
校准完第四个点后液晶界面是第一个矫正页面,
GMT+8, 2025-12-15 00:28 , Processed in 0.041232 second(s), 27 queries , Gzip On.
