查看: 14582|回复: 2
STM32能实现485和DMA的数据收发吗?
发表于 2015-4-17 09:26:40 | 显示全部楼层 |阅读模式
串口、DMA、中断配置代码如下:
void GPIO_Configuration(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
/* ?2?:?USART2 Tx?GPIO????????? */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
                            GPIO_ResetBits(GPIOD, GPIO_Pin_11);
void USART_Configuration(void)
//USART_ClearFlag(USART1, USART_FLAG_TC);
USART_InitStructure.USART_BaudRate = 115200;
USART_Init(USART2, &USART_InitStructure);
USART_ITConfig(USART2,USART_IT_TC,DISABLE);
USART_ITConfig(USART2,USART_IT_RXNE,DISABLE);
USART_ITConfig(USART2, USART_IT_IDLE , ENABLE);
USART_Cmd(USART2, ENABLE);
void DMA_Configuration(void)
/* DMA clock enable */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);//DMA1
/* DMA1 Channel4 (triggered by USART1 Tx event) Config */
DMA_DeInit(DMA1_Channel4);
DMA_InitStructure.DMA_PeripheralBaseAddr = USART2_BASE+4;
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)USART1_SEND_DATA;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
DMA_InitStructure.DMA_BufferSize = 512;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
DMA_Init(DMA1_Channel4, &DMA_InitStructure);
DMA_ITConfig(DMA1_Channel4, DMA_IT_TC, ENABLE);
/* Enable USART1 DMA TX request */
USART_DMACmd(USART2, USART_DMAReq_Tx, ENABLE);
//DMA_Cmd(DMA1_Channel4, DISABLE);
/* DMA1 Channel5 (triggered by USART1 Rx event) Config */
DMA_DeInit(DMA1_Channel5);
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)USART1_RECEIVE_DATA;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
DMA_Init(DMA1_Channel5, &DMA_InitStructure);
DMA_ITConfig(DMA1_Channel5, DMA_IT_TC, ENABLE);
/* Enable USART1 DMA RX request */
USART_DMACmd(USART2, USART_DMAReq_Rx, ENABLE);
DMA_Cmd(DMA1_Channel5, ENABLE);
void NVIC_Configuration(void)
/* Configure one bit for preemption priority */
/* Enable the USART2 Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
//Enable DMA Channel4 Interrupt
NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel4_IRQn;
/*Enable DMA Channel5 Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel5_IRQn;
中断处理函数代码:
void USART2_IRQHandler(void)
u16 DATA_LEN;
u16 i;
        u16 tmp;
if(USART_GetITStatus(USART2, USART_IT_IDLE) != RESET)//?????????
DMA_Cmd(DMA1_Channel5, DISABLE);//??DMA,?????????
//USART_RX_STA = USART1->SR;//??SR,???DR????
//USART_RX_STA = USART1->DR;
DATA_LEN=512-DMA_GetCurrDataCounter(DMA1_Channel5);
        tmp=USART1_RECEIVE_DATA[0];
        tmp=USART1_RECEIVE_DATA[1];
        tmp=USART1_RECEIVE_DATA[2];
if(DATA_LEN>0)
while(USART1_TX_Finish==0)//????????????
//????DMA????
for(i=0;i<DATA_LEN;i++)
USART1_SEND_DATA[i]=USART1_RECEIVE_DATA[i];
//USART?DMA??????????,?????????????????
DMA_Cmd(DMA1_Channel4, DISABLE); //??datasize?????????
DMA1_Channel4->CNDTR=DATA_LEN; //DMA1,?????
USART1_TX_Finish=0;//DMA???????
DMA_Cmd(DMA1_Channel4, ENABLE);
//DMA_Cmd(DMA1_Channel5, DISABLE);//??DMA,?????????
DMA_ClearFlag(DMA1_FLAG_GL5 | DMA1_FLAG_TC5 | DMA1_FLAG_TE5 | DMA1_FLAG_HT5);//???
DMA1_Channel5->CNDTR = 512;//???
DMA_Cmd(DMA1_Channel5, ENABLE);//???,??DMA
//?SR??DR??Idle
i = USART2->SR;
i = USART2->DR;
if(USART_GetITStatus(USART2, USART_IT_PE | USART_IT_FE | USART_IT_NE) != RESET)//??
USART_ClearITPendingBit(USART2, USART_IT_PE | USART_IT_FE | USART_IT_NE);
USART_ClearITPendingBit(USART2, USART_IT_TC);
USART_ClearITPendingBit(USART2, USART_IT_IDLE);
//USART1??DMA?????????
void DMA1_Channel4_IRQHandler(void)
DMA_ClearFlag(DMA1_FLAG_TC4);
DMA_Cmd(DMA1_Channel4, DISABLE);//??DMA
USART1_TX_Finish=1;//?DMA????
void DMA1_Channel5_IRQHandler(void)
DMA_ClearFlag(DMA1_FLAG_TC5);
说明:
同样的代码如果使用串口时能正常工作的, 但串口加了MAX485后不能进行正常数据收发(收到乱码,或不能收到数据)
请指教,谢谢
发表于 2015-4-17 10:11:26 | 显示全部楼层
485本质上是用串口,可以参考串口dma那个例程
 楼主| 发表于 2015-4-17 10:23:48 | 显示全部楼层
串口的已经实现了,就是485的不行。断点调试进入中断后发现 DMA没有收到任何数据,就是指定给DMA的buffer 没有任何数据。
GMT+8, 2024-9-22 06:58 , Processed in 0.031102 second(s), 23 queries , Gzip On.
