查看: 25902|回复: 2
我照源代码写的,为啥还有这么多错误。请大家帮我看看。
发表于 2015-4-22 22:05:29 | 显示全部楼层 |阅读模式
compiling main.c.....\..\User\LED\led.h(23): warning:  #1-D: last line of file ends without a newline
..\..\User\main.c(36): error:  #20: identifier "GPIO" is undefined
..\..\User\main.c(36): error:  #18: expected a ")"
..\..\User\main.c(37): error:  #18: expected a ")"
..\..\User\main.c(38): error:  #18: expected a ")"
..\..\User\main.c(42): error:  #18: expected a ")"
这是错误
36行          LED1( ON );                          // áá
37行                LED2( ON );                          // áá
38行         LED3( ON );                          // áá
                Delay(0x0FFFFF);
                Delay(0x0FFFFF);
                Delay(0x0FFFFF);
                LED1( OFF );                  // Ãe
                LED2( OFF );                  // Ãe
                LED3( OFF );                  // Ãe
 楼主| 发表于 2015-4-22 22:06:15 | 显示全部楼层
#define ON 0
#define OFF 1
#define LED1(a) if (a)  \
                          GPIO_SetBits(GPIOC,GPIO Pin 3);\
                    else  \
        GPIO_ResetBits(GPIOC,GPIO pin 3)
#define LED2(a) if (a)  \
                          GPIO_SetBits(GPIOC,GPIO Pin 4);\
                    else    \
        GPIO_ResetBits(GPIOC,GPIO pin 4)
#define LED3(a) if (a)  \
                          GPIO_SetBits(GPIOC,GPIO Pin 5);\
                    else    \
        GPIO_ResetBits(GPIOC,GPIO pin 5)
void LED_GPIO_Config(void);
#endif /*__LED_H*/
 楼主| 发表于 2015-4-22 22:06:36 | 显示全部楼层
这是写的led.h文件
GMT+8, 2025-12-14 22:43 , Processed in 0.040219 second(s), 24 queries , Gzip On.
