查看: 15327|回复: 1
图片显示
发表于 2015-4-23 22:11:59 | 显示全部楼层 |阅读模式
#include "bsp_bmp.h"
#include "bsp_ili9341.h"
FATFS bmpfs[2];
FIL bmpfsrc ,bmpfdst;
FRESULT bmpres;
UINT read_num;
void LCD_Show_Bmp(unsigned short int x, unsigned short int y,unsigned char *file_name)
        int i, j, k;
        int width, height, l_width;
        BYTE red,green,blue;
        BITMAPFILEHEADER bitfilehead;
        BITMAPINFOHEADER bitinfohead;
        WORD fileType;
        unsigned char temp_name[20];
        BYTE pColorData[960];
        sprintf((char*)temp_name,"0:%s",file_name);
        f_mount(0, &bmpfs[0]);
        bmpres = f_open( &bmpfsrc , (char *)temp_name, FA_OPEN_EXISTING | FA_READ);
        if(bmpres == FR_OK)
                f_read(&bmpfsrc,&fileType,sizeof(WORD),&read_num);
                f_read(&bmpfsrc,&bitfilehead,sizeof(bitfilehead),&read_num);
                f_read(&bmpfsrc,&bitinfohead,sizeof(bitinfohead),&read_num);
        width = bitinfohead.biWidth;
        height = bitinfohead.biHeight;
// ¼ÆËãλí¼μÄêμ¼ê¿í¶è2¢è·±£ËüÎa32μı¶êy
        l_width =Standard_width(width* bitinfohead.biBitCount);
        if(l_width > 960)
                return;
//éèÖÃLcd Gram é¨Ãè·½ÏòÎa: óòϽÇ->×óéϽÇ
        LCD_GramScan( 3 );
//¿aò»¸öí¼Æ¬′óD¡μÄ′°¿ú
        LCD_OpenWindows(x, y, width, height);
//ÅD¶ÏêÇ·ñêÇ24bitÕæ2êé«í¼
        if(bitinfohead.biBitCount >= 24)
                for(i=0;i< height; i++)
//                #if 0
//                                for(j=0; j< l_width; j++)
//                                        f_read(&bmpfsrc,pColorData+j,1,&read_num);
//                        #elif 1
                                f_read(&bmpfsrc,pColorData,l_width/2,&read_num);
                                f_read(&bmpfsrc,pColorData+l_width/2,l_width/2,&read_num);
//                #else
//                        f_read(&bmpfsrc,pColorData,l_width,&read_num);
//                        #endif
                        for(j=0; j<width; j++)        //ò&#187;DDóDD§D&#197;&#207;¢
                                k = j*3;        //ò&#187;DD&#214;DμúK&#184;&#246;&#207;&#241;&#203;&#216;μ&#196;&#198;eμ&#227;
                                red = pColorData[k+2];
                                green = pColorData[k+1];
                                blue =         pColorData[k];
                                LCD_WR_Data(RGB24TORGB16(red,green,blue)); //D′è&#235;LCD-GRAM
                return ;
        f_close(&bmpfsrc);
为什么把FIL bmpfsrc ,bmpfdst中的bmpfdst注释了就不能显示图片
发表于 2015-4-23 22:43:45 | 显示全部楼层
程序中没用到的话,去掉是应该的,怎么反而会运行出错呢,应该是程序哪里搞错了吧
GMT+8, 2024-11-28 00:37 , Processed in 0.058351 second(s), 23 queries , Gzip On.
