查看: 6890|回复: 2
[ucos] 求教ucos中使用printf串口输出浮点数据问题
发表于 2015-6-3 14:54:44 | 显示全部楼层 |阅读模式
在ucos中使用printf();输出浮点数据出错,但是直接输出字符和int型数据在串中调试助手中可以正确输出。网上说是字节对齐问题,可是我还是不知道怎么解决。。
 楼主| 发表于 2015-6-3 15:08:13 | 显示全部楼层
网上说的解决办法网址:http://m.blog.csdn.net/blog/dldw8816/38418227
2. 解决方法
我用的是IAR,通过#pragma data_alignment指定对齐字节数
#pragma data_alignment=8
OS_STK Task1_LED1_Stk[Task1_LED1_Stk_Size];
OS_STK Task2_backlight_Stk[Task2_backlight_Stk_Size];
所以我就依葫芦画瓢,在app.c中修改代码,加入一句#pragma data_alignment=8
如下:
  1. extern        OS_TCB        StartUp_TCB;
  2. static  OS_TCB        LED1_TCB;
  3. #pragma data_alignment=8
  4. static        CPU_STK        LED1_Stk[TASK_LED1_STK_SIZE];
  5. static  OS_TCB        LED2_TCB;
  6. static        CPU_STK        LED2_Stk[TASK_LED2_STK_SIZE];
  7. static  OS_TCB        LED3_TCB;
  8. static        CPU_STK        LED3_Stk[TASK_LED3_STK_SIZE];
 楼主| 发表于 2015-6-3 16:07:08 | 显示全部楼层
好吧,已经解决了。代码如下,强制八字节对齐命令__align(8)。
网址http://m.blog.csdn.net/blog/u010394032/39319285
  1. #include "app.h"
  2. extern        OS_TCB        StartUp_TCB;
  3. static  OS_TCB        LED1_TCB;
  4. #pragma data_alignment=8
  5. __align(8) static        CPU_STK        LED1_Stk[TASK_LED1_STK_SIZE];
  6. static  OS_TCB        LED2_TCB;
  7. static        CPU_STK        LED2_Stk[TASK_LED2_STK_SIZE];
  8. static  OS_TCB        LED3_TCB;
  9. static        CPU_STK        LED3_Stk[TASK_LED3_STK_SIZE];
GMT+8, 2025-4-16 00:57 , Processed in 0.122275 second(s), 23 queries , Gzip On.
