查看: 14142|回复: 3
有关DMA传送ADC的问题
发表于 2015-6-6 16:11:39 | 显示全部楼层 |阅读模式
      这两天在看ADC的实验,试着用直接输出何用DMA输出两种方式来试验,结果直接输出结果正常可以从0到3.2几V,但是用DMA传输就直接从0到0.1几V。
贴上代码,,麻烦各位帮忙看看。
#define ADC1_DR_Address ((uint32_t)0x40012400 + 0x4C)
uint16_t ADC_ConvertedValue;
static void GPIO_ADC_Configuration(void)
GPIO_InitTypeDef GPIO_Init_Structure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO,ENABLE);
GPIO_Init_Structure.GPIO_Mode = GPIO_Mode_AIN;
GPIO_Init_Structure.GPIO_Pin = GPIO_Pin_0;
GPIO_Init(GPIOC,&GPIO_Init_Structure);
void ADC_DMA_Configuration(void)
ADC_InitTypeDef ADC_Init_Structure;
DMA_InitTypeDef DMA_Init_Structure;
GPIO_ADC_Configuration();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);
DMA_DeInit(DMA1_Channel1);
DMA_Init_Structure.DMA_BufferSize = 1;    //´«ÊäµÄ´óС
DMA_Init_Structure.DMA_DIR = DMA_DIR_PeripheralSRC;   //ÍâÉè×÷ΪÊý¾Ý´«ÊäµÄÀ´Ô´
DMA_Init_Structure.DMA_M2M = DMA_M2M_Disable;
DMA_Init_Structure.DMA_MemoryBaseAddr = (uint32_t)&ADC_ConvertedValue;     //ÄÚ´æµØÖ·(Òª´«ÊäµÄ±äÁ¿µÄÖ¸Õë)
DMA_Init_Structure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;   //ÄÚ´æÊý¾Ýµ¥Î»
DMA_Init_Structure.DMA_MemoryInc = DMA_MemoryInc_Disable;     //Ö¸¶¨ÄÚ´æµØÖ·±£³Ö²»±ä
DMA_Init_Structure.DMA_Mode = DMA_Mode_Circular;      //²»¶ÏÑ »·
DMA_Init_Structure.DMA_PeripheralBaseAddr = ADC1_DR_Address;   //ADCµÄÊý¾ÝµØÖ·
DMA_Init_Structure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;    //ÍâÉèÊý¾Ýµ¥Î»
DMA_Init_Structure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;   //Ö¸¶¨ÍâÉèµØÖ·±£³Ö²»±ä
DMA_Init_Structure.DMA_Priority = DMA_Priority_Medium;
DMA_Init(DMA1_Channel1,&DMA_Init_Structure);
DMA_Cmd(DMA1_Channel1,ENABLE);
ADC_DeInit(ADC1);
ADC_Init_Structure.ADC_ContinuousConvMode = ENABLE;
ADC_Init_Structure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_Init_Structure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
ADC_Init_Structure.ADC_Mode = ADC_Mode_Independent;
ADC_Init_Structure.ADC_NbrOfChannel = 1;
ADC_Init_Structure.ADC_ScanConvMode = DISABLE;
ADC_Init(ADC1,&ADC_Init_Structure);
RCC_ADCCLKConfig(RCC_PCLK2_DiARM);  //ÅäÖÃADCʱÖÓ£¬×î´ó14M
ADC_RegularChannelConfig(ADC1,ADC_Channel_10,1,ADC_SampleTime_41Cycles5);  //¹æÔò×é
ADC_DMACmd(ADC1,ENABLE);
ADC_Cmd(ADC1,ENABLE);
ADC_ResetCalibration(ADC1);  //¸´Î»Ð£×¼
while(ADC_GetResetCalibrationStatus(ADC1));
ADC_StartCalibration(ADC1);  //¿ªÊ¼Ð£×¼
while(ADC_GetCalibrationStatus(ADC1));
ADC_SoftwareStartConvCmd(ADC1,ENABLE);
发表于 2015-6-6 16:49:36 | 显示全部楼层
发个测试过可行的给你,,你自己对照着改吧
  * @brief  使能ADC1和DMA1的时钟,初始化PC.01
  * @param  无
  * @retval 无
static void ADC1_GPIO_Config(void)
        /* Enable DMA clock */
        /* Enable ADC1 and GPIOC clock */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOC, ENABLE);
        /* Configure PC.0  as analog input */
  * @brief  配置ADC1的工作模式为MDA模式
  * @param  无
  * @retval 无
static void ADC1_Mode_Config(void)
        /* DMA channel1 configuration */
        DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;                                 //ADC地址
        DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;        //内存地址
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
        DMA_InitStructure.DMA_BufferSize = 1;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;        //外设地址固定
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;                                  //内存地址固定
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;        //半字
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;        //循环传输
        DMA_Init(DMA1_Channel1, &DMA_InitStructure);
        /* Enable DMA channel1 */
        DMA_Cmd(DMA1_Channel1, ENABLE);
        /* ADC1 configuration */
        ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;                        //独立ADC模式
        ADC_InitStructure.ADC_ScanConvMode = DISABLE ;                                          //禁止扫描模式,扫描模式用于多通道采集
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;                        //开启连续转换模式,即不停地进行ADC转换
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;        //不使用外部触发转换
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;         //采集数据右对齐
        ADC_InitStructure.ADC_NbrOfChannel = 1;        //要转换的通道数目1
        /*配置ADC时钟,为PCLK2的8分频,即9MHz*/
        /*配置ADC1的通道10为55.        5个采样周期,序列为1 */
        ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_55Cycles5);
        /* Enable ADC1 DMA */
        ADC_DMACmd(ADC1, ENABLE);
        /* Enable ADC1 */
        ADC_Cmd(ADC1, ENABLE);
        /*复位校准寄存器 */
        /*等待校准寄存器复位完成 */
        /* ADC校准 */
        /* 等待校准完成*/
        /* 由于没有采用外部触发,所以使用软件触发ADC转换 */
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);
发表于 2015-6-8 23:02:34 | 显示全部楼层
DataSize应该是HalfWord吧~~~~
发表于 2015-8-8 22:16:20 | 显示全部楼层
为什么不能用Byte?只能用HalfWord
GMT+8, 2025-1-10 17:46 , Processed in 0.033547 second(s), 23 queries , Gzip On.
