查看: 6887|回复: 1
[ucos] ucos_iii之源码求分析---OSSemCreate()
发表于 2015-7-13 15:42:34 | 显示全部楼层 |阅读模式
如下为ucos_iii的一段源码,恳请大神指教~~~
void  OSSemCreate (OS_SEM      *p_sem,
                   CPU_CHAR    *p_name,
                   OS_SEM_CTR   cnt,
                   OS_ERR      *p_err)
    CPU_SR_ALLOC();
#ifdef OS_SAFETY_CRITICAL                                  /*问题1:OS_SAFETY_CRITICAL是什么意思?*/
    if (p_err == (OS_ERR *)0) {
        OS_SAFETY_CRITICAL_EXCEPTION();
        return;
#endif
#ifdef OS_SAFETY_CRITICAL_IEC61508               /*问题2:OS_SAFETY_CRITICAL_IEC61508是什么意思?*/
    if (OSSafetyCriticalStartFlag == DEF_TRUE) {
        *p_err = OS_ERR_ILLEGAL_CREATE_RUN_TIME;
        return;
#endif
#if OS_CFG_CALLED_FROM_ISR_CHK_EN > 0u
    if (OSIntNestingCtr > (OS_NESTING_CTR)0) {
        *p_err = OS_ERR_CREATE_ISR;
        return;
#endif
#if OS_CFG_ARG_CHK_EN > 0u
    if (p_sem == (OS_SEM *)0) {
        *p_err = OS_ERR_OBJ_PTR_NULL;
        return;
#endif
    CPU_CRITICAL_ENTER();
    p_sem->Type    = OS_OBJ_TYPE_SEM;
    p_sem->Ctr     = cnt;
    p_sem->TS      = (CPU_TS)0;
    p_sem->NamePtr = p_name;
    OS_PendListInit(&p_sem->PendList);
#if OS_CFG_DBG_EN > 0u
    OS_SemDbgListAdd(p_sem);
#endif
    OSSemQty++;                               /*问题3:OSSemQty是什么意思?Qty是什么单词的缩写???*/
    CPU_CRITICAL_EXIT();
    *p_err = OS_ERR_NONE;
发表于 2015-11-2 12:05:24 | 显示全部楼层
GMT+8, 2025-4-9 14:41 , Processed in 0.074709 second(s), 24 queries , Gzip On.
