查看: 16740|回复: 2
按键问题 小白自己写了程序,为什么不行,求大神指导
发表于 2015-7-15 12:57:03 | 显示全部楼层 |阅读模式
#include "stm32f10x.h"
//#include "bsp_led.h"
//#include "bsp_key.h"
void RCC_Configuration(void);
void GPIO_Configuration(void);
//u32  count;
void delay(u32 count);
        RCC_Configuration();
        GPIO_Configuration();
                if(GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_13)==0)
                                GPIO_SetBits(GPIOB,GPIO_Pin_0);
                        //        delay(6000000);
                                GPIO_ResetBits(GPIOB,GPIO_Pin_0);
                                //delay(6000000);
        //RCC_DeInit();
//        RCC_HSEConfig(RCC_HSE_ON);//êÇÄüía2¿μĸßËùê±Öó
//        while(RCC_GetFlagStatus(RCC_FLAG_HSERDY) == RESET);//μè′yía2¿¸ßËùê±Öóê1Äü¾íD÷
        //FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);//ê1ÄüPrefetchBuffer
        //FLASH_SetLatency(FLASH_Latency_2);//Flash 2 wait state
//        RCC_HCLKConfig(RCC_SYSCLK_Div1);        //HCLK = SYSCLK2»·ÖÆμ
//        RCC_PCLK2Config(RCC_SYSCLK_Div1);//HCLK2 = HCLK
//        RCC_PCLK1Config(RCC_SYSCLK_Div2);//HCLK1 = HCLK/2
        //RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);//PLLCLK = 8MHz*9 = 72MHz
        //RCC_PLLCmd(ENABLE);//ê1ÄüPLLCLK
        //while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);//Wait till PLLCLK is ready
        //RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//Select PLL as system clock
        //while(RCC_GetSYSCLKSource() != 0x08); //Wait till PLL is used as system clock source
        //′ò¿aÏàó|íaéèê±Öó
        SystemInit();
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB ,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC ,ENABLE);
        //LED
        GPIO_Init(GPIOB,&GPIO_InitStructure);
//anjian
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
        // GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_Init(GPIOC,&GPIO_InitStructure);
        for(;count!=0;count--);
 楼主| 发表于 2015-7-15 13:26:07 | 显示全部楼层
大神求教  其中乱码的是注释
发表于 2015-7-16 08:46:43 | 显示全部楼层
你的是比较新的板子吧?新的板子一个按键按下是高电平,另一个按下是低电平,要注意区分,看看原理图
GMT+8, 2025-1-9 17:00 , Processed in 0.032735 second(s), 23 queries , Gzip On.
