查看: 13011|回复: 1
外部计数STM32 ETR计算频率问题
发表于 2015-7-22 16:43:25 | 显示全部楼层 |阅读模式
我用外部计数STM32 ETR计算频率,测量100K频率,用定时器2定时1S,定时器三PD2(TIM3_ETR)计数,计算公式f=n/t;测量出来的结果是9999 HZ,整整少了一位数字,这是什么原因呢,大家分析一下,谢谢,附我的程序
void Time3_Configuration()
   TIM_TimeBaseStructure.TIM_Prescaler = 0x00;
   TIM_TimeBaseStructure.TIM_Period = 0xFFFF;
   TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
   TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);  // Time base configuration
   TIM_ETRClockMode2Config(TIM3, TIM_ExtTRGPSC_OFF, TIM_ExtTRGPolarity_NonInverted, 0);
   //TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE);
   TIM_SetCounter(TIM3, 0);
   TIM_Cmd(TIM3, ENABLE);
         /*1S定时*/
void Tim2_Config(void)
    TIM_TimeBaseInitTypeDef   TIM2_TimeBaseStructure;
    TIM_DeInit(TIM2);
    TIM2_TimeBaseStructure.TIM_Period =999;
    TIM2_TimeBaseStructure.TIM_Prescaler = (7200-1);
    TIM2_TimeBaseStructure.TIM_ClockDivision = 0x0;//ÉèÖÃʱÖÓϵÊý ²»·ÖƵ
  TIM2_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//ÏòÉϼÆÊýģʽ
    TIM_TimeBaseInit(TIM2, &TIM2_TimeBaseStructure); // Time base configuration
    TIM_ClearFlag(TIM2,TIM_FLAG_Update);//Çå³þ¸üбê־λ
  TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE );
    TIM_Cmd(TIM2, ENABLE);
    NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
最后的计算部分:
void TIM2_IRQHandler(void)
        if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
             TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
             CAPTURE1=(u32)TIM_GetCounter(TIM3);
        sum+=CAPTURE1;
        count++;
        if(count==4)
         Frequency1=sum/4;//求频率公式F=n/t;这里求了4次的计数平均值,结果是1S的频率
       sum=0;
         count=0;
        TIM_SetCounter(TIM3,0);
 楼主| 发表于 2015-7-23 14:49:13 | 显示全部楼层
考虑到16位定时器65536会溢出,我定时250MS,现在测试100K-130K频率误差在8HZ-12HZ,不过每次测量频率变化,测量出来的数值有些不稳定 有些波动4HZ,怎么解决这个问题呢,有人么分析一下
GMT+8, 2024-11-23 23:58 , Processed in 0.025192 second(s), 23 queries , Gzip On.
