查看: 13536|回复: 3
keil4进行I2C硬件操作运行的时候产生这个警告
发表于 2015-8-26 23:40:24 | 显示全部楼层 |阅读模式
产生的警告目测是因为硬件的内存分布的问题,可是不会怎么处理这个问题,拜托大神了
不知道怎么解决这个问题
不知道怎么解决这个问题
发表于 2015-8-27 09:16:20 | 显示全部楼层
这个是你变量使用不够规范,你把相关代码贴出来看看
 楼主| 发表于 2015-8-27 22:02:40 | 显示全部楼层
#ifndef _USART_H_
#define _USART_H_
#include "stm32f10x.h"
#include "stdio.h"
void Usart_Config(void);
#endif
#include "usart.h"
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_USART1,ENABLE);
        /*配置PA9和PA10的管脚*/
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(GPIOA,&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
        /*配置串口usart1*/
           USART_InitStructure.USART_BaudRate=115200;
        USART_InitStructure.USART_WordLength=USART_WordLength_8b;
           USART_InitStructure.USART_StopBits=USART_StopBits_1;
        USART_InitStructure.USART_Parity=USART_Parity_No;
        USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;
        USART_Init(USART1,&USART_InitStructure);
        USART_Cmd(USART1,ENABLE);
int fputc(int ch,FILE *f)
        USART_SendData(USART1,(uint8_t)ch);
        while(USART_GetFlagStatus(USART1,USART_FLAG_TC==RESET));
        return ch;
int Fgetc(FILE *f)
        while(USART_GetFlagStatus(USART1,USART_FLAG_RXNE)==RESET);
        return (int)USART_ReceiveData(USART1);
#include "I2C.h"
#define I2C_Own_Address 0xA0
#define I2C_PageSize 8
#define I2C_Speed   400000
uint16_t Block_Address;
void I2C_InitConfig(void)
        I2C_InitTypeDef I2C_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_6|GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_OD;
        GPIO_Init(GPIOB,&GPIO_InitStructure);
        I2C_InitStructure.I2C_Mode=I2C_Mode_I2C;
        I2C_InitStructure.I2C_DutyCycle=I2C_DutyCycle_2;
        I2C_InitStructure.I2C_OwnAddress1=I2C_Own_Address;
        I2C_InitStructure.I2C_Ack=I2C_Ack_Enable;
        I2C_InitStructure.I2C_AcknowledgedAddress=I2C_AcknowledgedAddress_7bit;
        I2C_InitStructure.I2C_ClockSpeed=I2C_Speed;
        I2C_Init(I2C1,&I2C_InitStructure);
        I2C_Cmd(I2C1,ENABLE);
        #ifdef Block0_Address
                Block_Address=Block0_Address;
        #endif
        #ifdef Block1_Address
                Block_Address=Block1_Address;
        #endif
        #ifdef Block2_Address
                Block_Address=Block2_Address;
        #endif
        #ifdef Block3_Address
                Block_Address=Block3_Address;
        #endif
void I2C_BufferWrite(uint8_t *pBuffer,uint8_t WriteAddr,uint16_t NumByteWrite)//pBuffer缓冲区指针,WriteAddr写入的地址,NumByteWrite写的字节数
        uint8_t NumPage=0,NumSingle=0,Addr=0,Count=0;
        NumPage=NumByteWrite/I2C_PageSize;//要写进的数据的页数
        NumSingle=NumByteWrite%I2C_PageSize;//不足一页数据的个数
        Addr=WriteAddr%I2C_PageSize;//写入地址是每页的第几位
        Count=I2C_PageSize-Addr;//开始页写入的数据及其个数
        I2C_WaitStandbyStatus();//等待
        if(Addr==0)//说明写入的地址是第一页的开始
                if(NumPage==0)//说明写入的数据小于一页
                        I2C_PageWrite(pBuffer,WriteAddr,NumSingle);
                else//写入的数据大一或者等于一页
                        while(NumPage--)//检查页数的多少,少于一页后退出while
                                I2C_PageWrite(pBuffer,WriteAddr,I2C_PageSize);
                                WriteAddr+=I2C_PageSize;//更新地址和指针的数据,以便继续输出
                                pBuffer+=I2C_PageSize;
                        if(NumSingle!=0)//剩余数据少于一页
        else //开始的地址不是开始页的地址
                if(NumPage==0)//说明数据少于一页
                else//数据大于或者等于一页
                        NumByteWrite-=Count;
                        NumPage=NumByteWrite%I2C_PageSize;
                        if(Count!=0)
                                I2C_PageWrite(pBuffer,WriteAddr,Count);
                                WriteAddr+=Count;
                                pBuffer+=Count;
                        while(NumPage--)
                        if(NumSingle!=0)
/*时序产生的
EV5 I2C_EVENT_MASTER_MODE_SELECT
EV6 I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED
EV7        I2C_EVENT_MASTER_BYTE_RECEIVED
EARM        I2C_EVENT_MASTER_BYTE_TRANSMITTING
EARM_2  I2C_EVENT_MASTER_BYTE_TRANSMITTED
EV9        I2C_EVENT_MASTER_MODE_ADDRESS10
void I2C_PageWrite(uint8_t *pBuffer,uint8_t WriteAddr,uint16_t NumByteWrite)
        while(I2C_GetFlagStatus(I2C1,I2C_FLAG_BUSY));//如果I2C1不在忙的状态,那么进行数据的传送
        //参考零死角玩转STM32的第258页的时序
        I2C_GenerateSTART(I2C1,ENABLE);//发送开始信号
        while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_MODE_SELECT));//产生EV5并进行清除
        I2C_Send7bitAddress(I2C1,Block_Address,I2C_Direction_Transmitter);//发送7位地址
        while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
        I2C_SendData(I2C1,WriteAddr);//发送数据的地址
        while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTED));//产生EARM并清除
        while(NumByteWrite--)//写数据
                I2C_SendData(I2C1,*pBuffer); //通过外设I2C1发送数据
                pBuffer++;
                while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTED));//产生EARM并清除,并检查主机发送数据是否成功
        I2C_GenerateSTOP(I2C1,ENABLE); //数据发送结束
void I2C_ByteWrite(uint8_t* pBuffer, uint8_t WriteAddr)
        while(I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTED));
        while((!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED)));
        I2C_GenerateSTOP(I2C1, ENABLE);
void I2C_BufferRead(uint8_t *pBuffer,uint8_t ReadAddr,uint16_t NumByteRead)
        I2C_SendData(I2C1,ReadAddr);
        while(NumByteRead)
                if(1==NumByteRead)
                        I2C_AcknowledgeConfig(I2C1,DISABLE);
                /*测试EV7并清除*/
                if(I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_RECEIVED))
                        *pBuffer=I2C_ReceiveData(I2C1);
                        pBuffer++;
                        NumByteRead--;
        I2C_AcknowledgeConfig(I2C1,ENABLE);
void I2C_WaitStandbyStatus(void)
        vu16 Temp;
        do
                Temp=I2C_ReadRegister(I2C1,I2C_Register_SR1);
        while(!(I2C_ReadRegister(I2C1,I2C_Register_SR1)&0x0002));
        I2C_ClearFlag(I2C1,I2C_FLAG_AF);
#include "LED.h"
void LED_Config(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC,ENABLE);
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_3;
        GPIO_Init(GPIOC,&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_4;
        GPIO_SetBits(GPIOB,GPIO_Pin_0);
        GPIO_SetBits(GPIOC,GPIO_Pin_3|GPIO_Pin_4);
#include "I2C.h"
#include "usart.h"
#include "LED.h"
#define ON 0
#define OFF 1
#define FristPage 0x00
u8 I2C_Buf_Write[256];
u8 I2C_Buf_Read[256];
void I2C_Test(void)
        uint16_t i;
        printf("\r输入的数据:\n\r");
        for(i=0;i<256;i++)
                I2C_Buf_Write=i;
                printf("0x%02x ",I2C_Buf_Write);
                if(i%16==15)
                        printf("\n\r");
        LED1(ON);
        I2C_BufferWrite(I2C_Buf_Write,FristPage,256);
        LED1(OFF);
        printf("\n\t写入成功\t\t");
        printf("\n\t读出的数据\t\t");
        LED2(ON);
        I2C_BufferRead(I2C_Buf_Read,FristPage,256);
        LED2(OFF);
        for(i=0;i<256;i++)
                if(I2C_Buf_Write!=I2C_Buf_Read)
                        printf("0x%02X ",I2C_Buf_Read);
                        if(i%16==15)
                                printf("\n");
                        printf("\n\t错误,输入与输出不同");
                        return ;
                if(i%16==15)
                        printf("\n");
        printf("\n\n\r程序测试成功\n\r");
        LED_Config();
        Usart_Config();
        I2C_InitConfig();
        I2C_Test();
发表于 2015-8-28 09:41:54 | 显示全部楼层
单单看不出什么问题,不过都是警告对你程序运行有什么影响吗??
如果可能你把程序打包传上来,我编译看看
GMT+8, 2024-9-22 09:36 , Processed in 0.039192 second(s), 26 queries , Gzip On.
