查看: 12352|回复: 4
EmWin_GUIBUilder生成的代码导入模拟器不能用
发表于 2015-9-1 14:45:11 | 显示全部楼层 |阅读模式
    今天在使用 EmWin_GUIBUilder/uCGUIBulider 这二款软件,学习UCGUI,但在生成的代码后导入模拟仿真器后,发现uCGUIBulider生成的代码可以用;但EmWin_GUIBUilder确不能用!
想问一下大家有没有遇到这个问题,是什么原因造成的!!!
EmWin_GUIBUilder 生成的代码!!!!!(下面是)
*                SEGGER Microcontroller GmbH & Co. KG                *
*        Solutions for real time microcontroller applications        *
* C-file generated by:                                               *
*        GUI_Builder for emWin version 5.22                          *
*        Compiled Jul  4 2013, 15:16:01                              *
*        (c) 2013 Segger Microcontroller GmbH & Co. KG               *
*        Internet: www.segger.com  Support: support@segger.com       *
// USER START (Optionally insert additional includes)
// USER END
#include "DIALOG.h"
*       Defines
#define ID_FRAMEWIN_0  (GUI_ID_USER + 0x00)
#define ID_TEXT_0  (GUI_ID_USER + 0x01)
#define ID_BUTTON_0  (GUI_ID_USER + 0x02)
#define ID_CHECKBOX_0  (GUI_ID_USER + 0x05)
#define ID_PROGBAR_0  (GUI_ID_USER + 0x06)
#define ID_SCROLLBAR_0  (GUI_ID_USER + 0x07)
#define ID_SLIDER_0  (GUI_ID_USER + 0x08)
// USER START (Optionally insert additional defines)
// USER END
*       Static data
// USER START (Optionally insert additional static data)
// USER END
*       _aDialogCreate
static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
  { FRAMEWIN_CreateIndirect, "Framewin", ID_FRAMEWIN_0, 505, 111, 240, 320, 0, 0x0, 0 },
  { TEXT_CreateIndirect, "Text", ID_TEXT_0, 16, 33, 80, 20, 0, 0x64, 0 },
  { BUTTON_CreateIndirect, "Button", ID_BUTTON_0, 19, 65, 80, 20, 0, 0x0, 0 },
  { CHECKBOX_CreateIndirect, "Checkbox", ID_CHECKBOX_0, 21, 106, 80, 20, 0, 0x0, 0 },
  { PROGBAR_CreateIndirect, "Progbar", ID_PROGBAR_0, 18, 156, 80, 20, 0, 0x0, 0 },
  { SCROLLBAR_CreateIndirect, "Scrollbar", ID_SCROLLBAR_0, 22, 197, 80, 20, 0, 0x0, 0 },
  { SLIDER_CreateIndirect, "Slider", ID_SLIDER_0, 32, 239, 80, 20, 0, 0x0, 0 },
  // USER START (Optionally insert additional widgets)
  // USER END
*       Static code
// USER START (Optionally insert additional static code)
// USER END
*       _cbDialog
static void _cbDialog(WM_MESSAGE * pMsg) {
  WM_HWIN hItem;
  int     NCode;
  int     Id;
  // USER START (Optionally insert additional variables)
  // USER END
  switch (pMsg->MsgId) {
  case WM_INIT_DIALOG:
    // Initialization of 'Text'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_0);
    TEXT_SetText(hItem, "kljhkhlkjhkh");
    // Initialization of 'Checkbox'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_0);
    CHECKBOX_SetText(hItem, "Check");
    // USER START (Optionally insert additional code for further widget initialization)
    // USER END
    break;
  case WM_NOTIFY_PARENT:
    Id    = WM_GetId(pMsg->hWinSrc);
    NCode = pMsg->Data.v;
    switch(Id) {
    case ID_BUTTON_0: // Notifications sent by 'Button'
      switch(NCode) {
      case WM_NOTIFICATION_CLICKED:
        // USER START (Optionally insert code for reacting on notification message)
        // USER END
        break;
      case WM_NOTIFICATION_RELEASED:
        // USER END
        break;
      // USER START (Optionally insert additional code for further notification handling)
      // USER END
      break;
    case ID_CHECKBOX_0: // Notifications sent by 'Checkbox'
      switch(NCode) {
        // USER END
        break;
        // USER END
        break;
      case WM_NOTIFICATION_VALUE_CHANGED:
        // USER END
        break;
      // USER END
      break;
    case ID_SCROLLBAR_0: // Notifications sent by 'Scrollbar'
      switch(NCode) {
        // USER END
        break;
        // USER END
        break;
        // USER END
        break;
      // USER END
      break;
    case ID_SLIDER_0: // Notifications sent by 'Slider'
      switch(NCode) {
        // USER END
        break;
        // USER END
        break;
        // USER END
        break;
      // USER END
      break;
    // USER START (Optionally insert additional code for further Ids)
    // USER END
    break;
  // USER START (Optionally insert additional message handling)
  // USER END
  default:
    WM_DefaultProc(pMsg);
    break;
*       Public code
*       CreateFramewin
WM_HWIN CreateFramewin(void);
WM_HWIN CreateFramewin(void) {
  WM_HWIN hWin;
  hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
  return hWin;
// USER START (Optionally insert additional public code)
// USER END
/*************************** End of file ****************************/
导入模拟器后补写了一个主程序:
void MainTask(void)
GUI_Init();
WM_SetDesktopColor(GUI_RED);
WM_SetCreateFlags(WM_CF_MEMDEV);
CreateFramewin();
  WM_Exec();
发表于 2015-9-1 18:33:46 | 显示全部楼层
试了一下,用GUIBuilder工具生成的代码可以实现
*       CreateBreathing
WM_HWIN CreateBreathing(void) {
  WM_HWIN hWin;
  return hWin;
void MainTask(void) {
    GUI_Init();
    CreateBreathing();
    while (1)
        WM_Exec();
不知道你是哪里问题啊,试多几个工程看看
 楼主| 发表于 2015-9-2 09:14:02 | 显示全部楼层
你的这个软件,还是生成的全部代码,能不能上传一份资料,我下载下来看看
你用的是“GUI_CreateDialogBox();”!!!我分别试了一下 Framewin与Window都不行
发表于 2015-9-2 09:38:46 | 显示全部楼层
BreathingDLG.rar (1.38 KB, 下载次数: 17)
 楼主| 发表于 2015-9-2 09:43:17 | 显示全部楼层
我找到问题点了,是软件不能用,生成代码有问题
GMT+8, 2024-11-24 12:00 , Processed in 0.053137 second(s), 26 queries , Gzip On.
