查看: 14359|回复: 2
PWM波形出错,大神救救我吧!
发表于 2015-9-25 11:22:55 | 显示全部楼层 |阅读模式
  * @file    bsp_pwm_output.c
  * @author  STMicroelectronics
  * @version V1.0
  * @date    2013-xx-xx
  * @brief   tim3êä3öËÄ·pwm bsp
  * @attention
  * êμÑéƽì¨:ò°»e iSO STM32 ¿a·¢°å
  * ÂÛì3    :http://www.firebbs.cn
  * ìÔ±|    :http://firestm32.taobao.com
#include "bsp_pwm_output.h"
  * @brief  ÅäÖÃTIM3¸′óÃêä3&#246WMê±óÃμ½μÄI/O
  * @param  ÎT
  * @retval ÎT
static void TIM3_GPIO_Config(void)
        /* éèÖÃTIM3CLK Îa 72MHZ */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  /* GPIOA and GPIOB clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB, ENABLE);
  /*GPIOA Configuration: TIM3 channel 1 and 2 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                    // ¸′óÃíÆíìêä3ö
  /*GPIOB Configuration: TIM3 channel 3 and 4 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_0 | GPIO_Pin_1;
  * @brief  ÅäÖÃTIM3êä3öμ&#196WMDÅoÅμÄģ꽣¬èçÖüÆú¡¢¼«DÔ¡¢Õ¼¿Õ±è
  * @param  ÎT
  * @retval ÎT
* TIMxCLK/CK_PSC --> TIMxCNT --> TIMx_ARR --> TIMxCNT ÖØD¼Æêy
*                    TIMx_CCR(μçƽ·¢éú±ä»ˉ)
* DÅoÅÖüÆú=(TIMx_ARR +1 ) * ê±ÖóÖüÆú
* Õ¼¿Õ±è=TIMx_CCR/(TIMx_ARR +1)
static void TIM3_Mode_Config(void)
        /* PWMDÅoÅμçƽìø±äÖμ */
         u16 CCR1_Val = 500;
         u16 CCR2_Val = 375;
         u16 CCR3_Val = 250;
         u16 CCR4_Val = 125;
    TIM3 Channel1 duty cycle = (TIM3_CCR1/ TIM3_ARR+1)* 100% = 50%
    TIM3 Channel2 duty cycle = (TIM3_CCR2/ TIM3_ARR+1)* 100% = 37.5%
    TIM3 Channel3 duty cycle = (TIM3_CCR3/ TIM3_ARR+1)* 100% = 25%
    TIM3 Channel4 duty cycle = (TIM3_CCR4/ TIM3_ARR+1)* 100% = 12.5%
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 999;       //챶¨ê±Æ÷′ó0¼Æêyμ½999£¬¼′Îa1000′Σ¬Îaò»¸ö¶¨ê±ÖüÆú
  TIM_TimeBaseStructure.TIM_Prescaler = 0;            //éèÖÃÔ¤·ÖÆμ£o2»Ô¤·ÖÆ죬¼′Îa72MHz
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;        //éèÖÃê±Öó·ÖÆμÏμêy£o2»·ÖÆμ(ÕaàïóÃ2»μ½)
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //ÏòéϼÆêyÄ£ê½
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  /* PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;            //ÅäÖÃÎaPWMÄ£ê½1
  TIM_OCInitStructure.TIM_Pulse = CCR1_Val;           //éèÖÃìø±äÖμ£¬μ±¼ÆêyÆ÷¼Æêyμ½Õa¸öÖμê±£¬μçƽ·¢éúìø±ä
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;  //챶¨ê±Æ÷¼ÆêyÖμD¡óúCCR1_Valê±Îa¸ßμçƽ
  TIM_OC1Init(TIM3, &TIM_OCInitStructure);         //ê1Äüí¨μà1
  TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
  /* PWM1 Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_Pulse = CCR2_Val;          //éèÖÃí¨μà2μÄμçƽìø±äÖ죬êä3öáííaò»¸öÕ¼¿Õ±èμ&#196WM
  TIM_OC2Init(TIM3, &TIM_OCInitStructure);          //ê1Äüí¨μà2
  TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
  /* PWM1 Mode configuration: Channel3 */
  TIM_OCInitStructure.TIM_Pulse = CCR3_Val;        //éèÖÃí¨μà3μÄμçƽìø±äÖ죬êä3öáííaò»¸öÕ¼¿Õ±èμ&#196WM
  TIM_OC3Init(TIM3, &TIM_OCInitStructure);         //ê1Äüí¨μà3
  TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
  /* PWM1 Mode configuration: Channel4 */
  TIM_OCInitStructure.TIM_Pulse = CCR4_Val;        //éèÖÃí¨μà4μÄμçƽìø±äÖ죬êä3öáííaò»¸öÕ¼¿Õ±èμ&#196WM
  TIM_OC4Init(TIM3, &TIM_OCInitStructure);        //ê1Äüí¨μà4
  TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM3, ENABLE);                         // ê1ÄüTIM3ÖØÔؼÄ′æÆ÷ARR
  /* TIM3 enable counter */
  TIM_Cmd(TIM3, ENABLE);                   //ê1Äü¶¨ê±Æ÷3
  * @brief  TIM3 êä3&#246WMDÅoÅ3õê¼»ˉ£¬Ö»òaμ÷óÃÕa¸öoˉêy
  *         TIM3μÄËĸöí¨μà¾í»áóDPWMDÅoÅêä3ö
  * @param  ÎT
  * @retval ÎT
void TIM3_PWM_Init(void)
        TIM3_GPIO_Config();
        TIM3_Mode_Config();
这程序没错啊,为什么我用软件仿真,出来的波形都是一条直线啊,全为低电平????到底为什么啊啊啊啊啊?????????????????
 楼主| 发表于 2015-9-25 11:33:45 | 显示全部楼层
有时出来正确波形,有时又不对,可是都是原来的程序怎么回事??
 楼主| 发表于 2015-9-25 11:39:27 | 显示全部楼层
现在波形正常了,可是为什么把占空比改了,异步电机就不动了啊?????
u16 CCR3_Val = 250;改成了u16 CCR3_Val = 500;
GMT+8, 2025-1-10 21:59 , Processed in 0.030880 second(s), 23 queries , Gzip On.
