查看: 14968|回复: 2
mpu6050数据存储到sd卡,为什么是乱码?求解
发表于 2015-10-20 15:25:57 | 显示全部楼层 |阅读模式
#include "stm32f10x.h"
#include "bsp_sdio_sdcard.h"
#include "bsp_usart1.h"
#include "ff.h"
#include "mpu6050.h"
#include "bsp_i2c.h"
#include "stm32f10x_it.h"
#define uchar unsi
                   #define TASK_ENABLE 0
                                                  extern unsigned int Task_Delay[NumOfTask];
FIL fnew;
        /* file objects */
FATFS fs;        /* Work area (file system object) for logical drives */
FRESULT res;
UINT br, bw;                                                    /* File R/W count */
BYTE buffer[4096]={0};                         /* file copy buffer */
BYTE textFileBuffer[] = "Welcome to use Wildfire iso stm32 Development Board today is a good day";
short  Accel[3];
short Gyro[3];
short Temp;
void delay (int x)
{  int i,j;
    for (i=0;i<x;i++)
       for(j=0;j<600;j++);
    i2c_GPIO_Config();
  //MPU6050初始化
        MPU6050_Init();
   /* USART1 config */
                USART1_Config();
                printf("\r\n 飞行数据采集系统 \r\n");
                /* Sdio Interrupt Config */
                NVIC_Configuration();
                /* Register work area for each volume (Always succeeds regardless of disk status) */
                f_mount(0,&fs);
                /* function disk_initialize() has been called in f_open */
                /* Create new file on the drive 0 */
                res = f_open(&fnew, "0:飞行数据.txt", FA_CREATE_ALWAYS | FA_WRITE );
                delay(5000);
                         if(Task_Delay[1]==0)
                        MPU6050ReadAcc(Accel);
                //        printf("\r\n加速度: %8d%8d%8d    ",Accel[0],Accel[1],Accel[2]);
                        MPU6050ReadGyro(Gyro);
                //        printf("陀螺仪: %8d%8d%8d    ",Gyro[0],Gyro[1],Gyro[2]);
                        MPU6050_ReturnTemp(&Temp);
                //        printf("温度: %d",Temp);
                        Task_Delay[1]=100;//此值每1ms会减1,减到0才可以重新进来这里,所以执行的周期是100ms
                if ( res == FR_OK )
                        res = f_write(&fnew, Accel, sizeof(Accel), &bw);
                        res = f_write(&fnew, Gyro, sizeof(Gyro), &bw);
                                //         f_sync(&fnew);
                                   f_lseek(&fnew, 500);//移动文件指针
                                 // f_lseek(&fnew, f_size(&fnew));
                        f_close(&fnew);
                res = f_open(&fnew, "0飞行数据.txt", FA_OPEN_EXISTING | FA_READ);
                res = f_read(&fnew, buffer, sizeof(buffer), &br);
                printf("\r\n %s ", buffer);
                /* Close open files */
                f_close(&fnew);
    /* Unregister work area prior to discard it */
    f_mount(0, NULL);
发表于 2015-10-20 19:56:32 | 显示全部楼层
你直接往txt格式的文件写入原始数据,自然是会错了。
你要先用sprintf函数把数据转化成字符串,再进行写入,这样打开txt文件才不会错
 楼主| 发表于 2015-10-20 21:49:23 | 显示全部楼层
你要先用sprintf函数把数据转化成字符串,再进行写入 ...
我试试,多谢了啊哈
GMT+8, 2025-12-14 11:46 , Processed in 0.044325 second(s), 24 queries , Gzip On.
