查看: 16314|回复: 2
文件系统SD卡存数据。为啥存一些就存不进去了
发表于 2015-10-24 10:18:51 | 显示全部楼层 |阅读模式
我是实时往里面存的传感器数据,但是存一些后就去了,是怎么回事
发表于 2015-10-25 23:54:00 | 显示全部楼层
你是不是地址重复了
 楼主| 发表于 2015-10-26 10:38:59 | 显示全部楼层
小菜鸟123 发表于 2015-10-25 23:54
你是不是地址重复了
#include "stm32f10x.h"
#include "bsp_sdio_sdcard.h"
#include "bsp_usart1.h"
#include "ff.h"
#include "mpu6050.h"
#include "bsp_i2c.h"
#include "stm32f10x_it.h"
   #include "stdio.h"
#define uchar unsi
#define TASK_ENABLE 0
extern unsigned int Task_Delay[NumOfTask];
FIL fnew;
u8 i=0;
u8 byte;        /* file objects */
FATFS fs;        /* Work area (file system object) for logical drives */
FRESULT res;
UINT br, bw;                                                    /* File R/W count */
BYTE buffer[10000];                         /* file copy buffer */
BYTE write_buf[10];
short Accel[3];
u8 flag=0,j=0;
short Gyro[3];
short Temp;
u16 pointer=0;
void delay (int x)
{  int i,j;
    for (i=0;i<x;i++)
       for(j=0;j<600;j++);
//void num2char(short *write_buf)
//                 write_buf[0]=Accel[0]/10000+0X30;
//                        write_buf[1]=Accel[0]%10000/1000+0X30;
//                        write_buf[2]=Accel[0]%1000/100+0X30;
//                        write_buf[3]=Accel[0]%100/10+0X30;
//                        write_buf[4]=Accel[0]%10+0X30;
//                        write_buf[5]=',';
void read(void)
            res = f_open(&fnew, "0:飞行数据.txt", FA_OPEN_EXISTING | FA_READ);
                pointer=fnew.fsize;
                        res=f_read(&fnew, buffer,sizeof(buffer) , &br);
                     printf("\r\n %s ", buffer);
                    printf("\r\n完成\r\n\r\n"  );
                    f_close(&fnew);
    i2c_GPIO_Config();
  //MPU6050初始化
        MPU6050_Init();
                USART1_Config();
                printf("\r\n 飞行数据采集系统 \r\n");
                NVIC_Configuration();
                f_mount(0,&fs);
        res = f_open(&fnew, "0:飞行数据.txt", FA_CREATE_ALWAYS | FA_WRITE );
//                 pointer=fnew.fsize; //获得文件大小
//                res=f_lseek(&fnew,pointer);//移动文件指针
//           res=f_write(&fnew,buffer,byte,&br);
//       res=f_sync(&fnew);
f_close(&fnew);
                     delay(10000);
                if(Task_Delay[1]==0)
                        MPU6050ReadAcc(Accel);
                    printf("\r\n加速度参考:%8d",Accel[0] );
                        write_buf[0]='*';
                        write_buf[1]='*';
                        write_buf[2]=':';
                        write_buf[3]=Accel[0]/10000+0X30;
                        write_buf[4]=Accel[0]%10000/1000+0X30;
                        write_buf[5]=Accel[0]%1000/100+0X30;
                        write_buf[6]=Accel[0]%100/10+0X30;
                        write_buf[7]=Accel[0]%10+0X30;
                        write_buf[8]=0x0d;
                        write_buf[9]=0x0a;
                   // write_buf[6]='\r' ;
                  // printf("\r\n加速度: %8d%8d%8d",Accel[0],Accel[1],Accel[2] );
                //        MPU6050ReadGyro(Gyro);
                //        printf("陀螺仪: %8d%8d%8d    ",Gyro[0],Gyro[1],Gyro[2]);
                //        MPU6050_ReturnTemp(&Temp);
                  //  printf("\r温度:%d",Temp);
               //        printf("\r\n采集成功%d\r\n",i );
                //  Task_Delay[1]=100;//此值每1ms会减1,减到0才可以重新进来这里,所以执行的周期是100ms
                if ( res == FR_OK )
                //        sprintf(FLIGHTBUFF,"%s",&Accel);
                        //res = f_write(&fnew, Accel,2, &bw);
                        //res = f_write(&fnew, &Accel[1],2, &bw);
                //        res = f_write(&fnew, &Accel[2],2, &bw);
                        pointer=fnew.fsize;
                        res=f_lseek(&fnew,pointer+j);
                           res = f_write(&fnew, write_buf, sizeof(write_buf), &bw);
                        res=f_sync(&fnew);
                        i++;
                        // f_lseek(&fnew, f_size(&fnew));
                        f_close(&fnew);
                       printf("\r\n写成功%d",i );
                        j=j+10;
                        read();
                        delay(50);
//                    res = f_open(&fnew, "0:飞行数据.txt", FA_OPEN_EXISTING | FA_READ);
//                        res=f_read(&fnew, buffer,sizeof(buffer) , &br);
//                     printf("\r\n %s ", buffer);
//                    printf("\r\n最后一句\r\n\r\n"  );
//                   f_close(&fnew);
                /* Close open files */
    /* Unregister work area prior to discard it */
    f_mount(0, NULL);
GMT+8, 2025-1-11 01:38 , Processed in 0.035182 second(s), 23 queries , Gzip On.
