查看: 7189|回复: 2
F429开发板例程编译出错!
发表于 2016-10-23 21:37:09 | 显示全部楼层 |阅读模式
编译F429所带 2.wifi_ov2640 例程出错!错误信息如下:这里有个问题需要说明下,就是编译器版本的问题,因为我一直使用的是MDK5.18的版本,所以编译器版本稍有不同。
如果是编译器版本的问题该如何解决呢?
compiling ov2640_Init.c...
compiling ov2640_SCCB.c...
compiling bsp_sdram.c...
linking...
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6654E: Rejected Local symbol .text7 referred to from non group member internal.o(.iar.stackusage)
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #25 '$t' in .bss(mxchipWNET.o:7) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #26 '$t' in .bss(mxchipWNET.o:8) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #27 '$t' in .bss(mxchipWNET.o:9) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #28 '$t' in .bss(mxchipWNET.o:10) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #172 '$t' in .bss(mxchipWNET.o:12) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #173 '$t' in .bss(mxchipWNET.o:13) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #198 '$t' in .bss(mxchipWNET.o:14) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #233 '$t' in .bss(mxchipWNET.o:15) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #213 '$t' in .bss(ssl.o:7) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #214 '$t' in .bss(ssl.o:8) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #304 '$t' in .bss(ssl.o:10) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #305 '$t' in .bss(ssl.o:11) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #306 '$t' in .bss(ssl.o:12) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #148 '$t' in .bss(tasks.o:32) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #316 '$t' in .bss(wifimgr.o:138) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #11 '$t' in .bss(dnsclient.o:7) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #12 '$t' in .bss(dnsclient.o:8) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #36 '$t' in .bss(ostimers.o:12) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #15 '$t' in .bss(udp.o:8) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #42 '$t' in .bss(wifi.o:16) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #39 '$t' in .bss(wps_host.o:7) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #40 '$t' in .bss(wps_host.o:8) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #41 '$t' in .bss(wps_host.o:9) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #42 '$t' in .bss(wps_host.o:10) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #43 '$t' in .bss(wps_host.o:11) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #44 '$t' in .bss(wps_host.o:12) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #45 '$t' in .bss(wps_host.o:13) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #46 '$t' in .bss(wps_host.o:14) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #47 '$t' in .bss(wps_host.o:15) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #48 '$t' in .bss(wps_host.o:16) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #49 '$t' in .bss(wps_host.o:17) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #50 '$t' in .bss(wps_host.o:18) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #51 '$t' in .bss(wps_host.o:19) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #52 '$t' in .bss(wps_host.o:20) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #53 '$t' in .bss(wps_host.o:21) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #54 '$t' in .bss(wps_host.o:22) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #55 '$t' in .bss(wps_host.o:23) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #56 '$t' in .bss(wps_host.o:24) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #14 '$t' in .bss(wwd_internal.o:9) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #50 '$t' in .bss(wwd_internal.o:10) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #120 '$t' in .bss(wwd_wifi.o:55) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #16 '$t' in .bss(netif.o:10) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches tasks.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches dnsclient.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches mxchipWNET.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wifi.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wifimgr.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches ostimers.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches udp.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wwd_internal.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wwd_wifi.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches netif.o(.bss).
Not enough information to list image symbols.
Not enough information to list the image map.
Finished: 2 information, 43 warning and 37 error messages.
"..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf" - 37 Error(s), 59 Warning(s).
Target not created.
Build Time Elapsed:  00:02:06
不知道出错原因,还请火哥帮忙看下!
具体编译信息如下:
μVision Build LogTool Versions:IDE-Version: |ìVision V5.18aCopyright (C) 2016 ARM Ltd and ARM Germany GmbH. All rights reserved.License Information: GJ Ma, Sum, LIC=Y2B45-G16EW-JPFZQ-NADK3-M23WB-T2LE8 Tool Versions:Toolchain:       MDK-ARM Professional  Version: 5.18aToolchain Path:  E:\WIN7\RealViewMDK5.18\Keil_v5\ARM\ARMCC\BinC Compiler:      Armcc.exe V5.06 update 1 (build 61)Assembler:       Armasm.exe V5.06 update 1 (build 61)Linker/Locator:  ArmLink.exe V5.06 update 1 (build 61)Library Manager: ArmAr.exe V5.06 update 1 (build 61)Hex Converter:   FromElf.exe V5.06 update 1 (build 61)CPU DLL:         SARMCM3.DLL V5.18aDialog DLL:      DCM.DLL V1.13.6.0Target DLL:      CMSIS_AGDI.dll V1.25.14.0Dialog DLL:      TCM.DLL V1.14.8.0 Project:F:\MyProgram\xxx\Projects\STM32F429\demo\RVMDK\demo.uvprojxProject File Date:  10/21/2016Output:*** Using Compiler 'V5.05 update 2 (build 169)', folder: 'E:\WIN7\RealViewMDK5.18\Keil_v5\ARM\ARMCC\Bin'Rebuild target 'MICO-Fire-OV2640'compiling fire_demo.c...compiling tcp_server.c...compiling AESUtils.c...compiling CheckSumUtils.c...compiling platform.c...compiling camera_data_queue.c.....\..\..\..\Demos\fire\ov2640\camera_data_queue.c(197): warning:  #177-D: variable "len_p_get" was declared but never referenced                  int32_t len_p_get = 0 ;                ..\..\..\..\Demos\fire\ov2640\camera_data_queue.c(200): warning:  #177-D: variable "time_old" was declared but never referenced                  uint32_t time_old,time_new;..\..\..\..\Demos\fire\ov2640\camera_data_queue.c(200): warning:  #177-D: variable "time_new" was declared but never referenced                  uint32_t time_old,time_new;..\..\..\..\Demos\fire\ov2640\camera_data_queue.c(303): warning:  #177-D: variable "z" was declared but never referenced      uint32_t i = 0,j=0,z=0;..\..\..\..\Demos\fire\ov2640\camera_data_queue.c: 4 warnings, 0 errorscompiling RingBufferUtils.c...compiling SecurityUtils.c...compiling SHAUtils.c...compiling SocketUtils.c...compiling HTTPUtils.c...compiling StringUtils.c...compiling URLUtils.c...compiling TLVUtils.c...compiling TimeUtils.c...compiling httpd.c...compiling http_parse.c...compiling httpd_handle.c...compiling httpd_ssi.c...compiling httpd_sys.c...compiling http-strings.c...compiling arraylist.c...compiling debug.c...compiling json_object.c...compiling json_util.c...compiling httpd_wsgi.c...compiling linkhash.c...compiling printbuf.c...compiling mico_config.c...compiling json_tokener.c...compiling hkdf.c...compiling hmac.c...compiling sha1.c...compiling sha224-256.c...compiling usha.c...compiling sha384-512.c...compiling wlan_firmware.c...compiling curve25519-donna.c...compiling mico_cli.c...compiling config_server_menu.c...compiling config_server.c...compiling system_easylink.c...compiling system_easylink_wac.c...compiling system_easylink_delegate.c...compiling mico_mdns.c...compiling mico_system_init.c...compiling tftp_ota.c...compiling mico_system_monitor.c...compiling mico_system_notification.c...compiling mico_system_para_storage.c...compiling mico_system_power_daemon.c...compiling system_factory_test.c...compiling system_misc.c...compiling crt0_RVMDK.c...compiling airkiss_discovery.c...compiling system_discovery.c...compiling hardfault.c...compiling memory_debugger.c...compiling thread_safe.c...compiling Retarget.c...compiling temp_hum_sensor.c...compiling micokit_ext.c...compiling micokit_ext_mfg.c...compiling AsciiLib.c...compiling dc_motor.c...compiling oled.c...compiling MiCOKit_STmems.c...compiling rgb_led.c...compiling hsb2rgb_led.c...compiling apds9930.c...compiling bme280.c...compiling bma2x2.c...compiling bma2x2_user.c...compiling bmg160.c...compiling bme280_user.c...compiling bmm050.c.....\..\..\..\Platform\Drivers\sensor\BMM050\bmm050.c(1969): warning:  #1035-D: single-precision operand implicitly converted to double-precision                          inter_retval = ((((float)p_bmm050->dig_xyz1)..\..\..\..\Platform\Drivers\sensor\BMM050\bmm050.c(1976): warning:  #1035-D: single-precision operand implicitly converted to double-precision                          (inter_retval*inter_retval /..\..\..\..\Platform\Drivers\sensor\BMM050\bmm050.c(1978): warning:  #1035-D: single-precision operand implicitly converted to double-precision                          inter_retval * ((float)p_bmm050->dig_xy1)..\..\..\..\Platform\Drivers\sensor\BMM050\bmm050.c(1980): warning:  #1035-D: single-precision operand implicitly converted to double-precision                          (((float)p_bmm050->dig_x2) + 160.0)))..\..\..\..\Platform\Drivers\sensor\BMM050\bmm050.c(1982): warning:  #1035-D: single-precision operand implicitly converted to double-precision                          + (((float)p_bmm050->dig_x1) *..\..\..\..\Platform\Drivers\sensor\BMM050\bmm050.c(2082): warning:  #1035-D: single-precision operand implicitly converted to double-precision                          inter_retval = ((((float)p_bmm050->dig_xyz1)..\..\..\..\Platform\Drivers\sensor\BMM050\bmm050.c(2090): warning:  #1035-D: single-precision operand implicitly converted to double-precision                          (inter_retval*inter_retval..\..\..\..\Platform\Drivers\sensor\BMM050\bmm050.c(2092): warning:  #1035-D: single-precision operand implicitly converted to double-precision                          inter_retval * ((float)p_bmm050->dig_xy1)..\..\..\..\Platform\Drivers\sensor\BMM050\bmm050.c(2095): warning:  #1035-D: single-precision operand implicitly converted to double-precision                          (((float)p_bmm050->dig_y2) + 160.0)))..\..\..\..\Platform\Drivers\sensor\BMM050\bmm050.c(2097): warning:  #1035-D: single-precision operand implicitly converted to double-precision                          (((float)p_bmm050->dig_y1) * 8.0))..\..\..\..\Platform\Drivers\sensor\BMM050\bmm050.c(2223): warning:  #1035-D: single-precision operand implicitly converted to double-precision                          inter_retval = ((((((float)mag_data_z)-..\..\..\..\Platform\Drivers\sensor\BMM050\bmm050.c(2228): warning:  #1035-D: single-precision operand implicitly converted to double-precision                          ((float)p_bmm050->dig_z1)*((float)data_r) /..\..\..\..\Platform\Drivers\sensor\BMM050\bmm050.c: 12 warnings, 0 errorscompiling bmg160_user.c...compiling bmm050_user.c...compiling DHT11.c...compiling hts221.c...compiling infrared_reflective.c...compiling light_sensor.c...compiling lps25hb.c...compiling lsm9ds1_acc_gyr.c...compiling lsm9ds1_mag.c...compiling uvis25.c...compiling spi_flash.c...compiling spi_flash_platform.c...compiling button.c...compiling mico_platform_common.c...assembling startup_stm32f429_RVMDK.s...compiling wlan_platform_common.c...compiling platform_init.c...compiling wlan_bus_sdio.c...compiling misc.c...compiling wlan_platform.c...compiling stm32f4xx_adc.c...compiling stm32f4xx_can.c...compiling stm32f4xx_crc.c...compiling stm32f4xx_cryp.c...compiling stm32f4xx_cryp_des.c...compiling stm32f4xx_cryp_tdes.c...compiling stm32f4xx_cryp_aes.c...compiling stm32f4xx_dcmi.c...compiling stm32f4xx_dac.c...compiling stm32f4xx_dbgmcu.c...compiling stm32f4xx_exti.c...compiling stm32f4xx_dma.c...compiling stm32f4xx_dma2d.c...compiling stm32f4xx_flash.c...compiling stm32f4xx_gpio.c...compiling stm32f4xx_flash_ramfunc.c...compiling stm32f4xx_hash_sha1.c...compiling stm32f4xx_hash_md5.c...compiling stm32f4xx_hash.c...compiling stm32f4xx_iwdg.c...compiling stm32f4xx_i2c.c...compiling stm32f4xx_ltdc.c...compiling stm32f4xx_rng.c...compiling stm32f4xx_pwr.c...compiling stm32f4xx_rcc.c...compiling stm32f4xx_sai.c...compiling stm32f4xx_sdio.c...compiling stm32f4xx_rtc.c...compiling stm32f4xx_spi.c...compiling stm32f4xx_syscfg.c...compiling stm32f4xx_tim.c...compiling stm32f4xx_usart.c...compiling stm32f4xx_wwdg.c...compiling stm32f4xx_fmc.c...compiling paltform_rtc.c...compiling platform_adc.c...compiling platform_flash.c...compiling platform_gpio.c...compiling platform_i2c.c...compiling platform_mcu_powersave.c...compiling platform_nano_second.c...compiling platform_pwm.c...compiling platform_rng.c...compiling platform_spi.c...compiling platform_watchdog.c...compiling platform_uart.c...compiling ov2640_Init.c...compiling ov2640_SCCB.c...compiling bsp_sdram.c...linking.....\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6654E: Rejected Local symbol .text7 referred to from non group member internal.o(.iar.stackusage)..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #25 '$t' in .bss(mxchipWNET.o:7) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #26 '$t' in .bss(mxchipWNET.o:8) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #27 '$t' in .bss(mxchipWNET.o:9) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #28 '$t' in .bss(mxchipWNET.o:10) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #172 '$t' in .bss(mxchipWNET.o:12) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #173 '$t' in .bss(mxchipWNET.o:13) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #198 '$t' in .bss(mxchipWNET.o:14) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #233 '$t' in .bss(mxchipWNET.o:15) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #213 '$t' in .bss(ssl.o:7) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #214 '$t' in .bss(ssl.o:8) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #304 '$t' in .bss(ssl.o:10) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #305 '$t' in .bss(ssl.o:11) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #306 '$t' in .bss(ssl.o:12) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #148 '$t' in .bss(tasks.o:32) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #316 '$t' in .bss(wifimgr.o:138) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #11 '$t' in .bss(dnsclient.o:7) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #12 '$t' in .bss(dnsclient.o:8) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #36 '$t' in .bss(ostimers.o:12) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #15 '$t' in .bss(udp.o:8) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #42 '$t' in .bss(wifi.o:16) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #39 '$t' in .bss(wps_host.o:7) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #40 '$t' in .bss(wps_host.o:8) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #41 '$t' in .bss(wps_host.o:9) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #42 '$t' in .bss(wps_host.o:10) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #43 '$t' in .bss(wps_host.o:11) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #44 '$t' in .bss(wps_host.o:12) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #45 '$t' in .bss(wps_host.o:13) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #46 '$t' in .bss(wps_host.o:14) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #47 '$t' in .bss(wps_host.o:15) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #48 '$t' in .bss(wps_host.o:16) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #49 '$t' in .bss(wps_host.o:17) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #50 '$t' in .bss(wps_host.o:18) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #51 '$t' in .bss(wps_host.o:19) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #52 '$t' in .bss(wps_host.o:20) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #53 '$t' in .bss(wps_host.o:21) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #54 '$t' in .bss(wps_host.o:22) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #55 '$t' in .bss(wps_host.o:23) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #56 '$t' in .bss(wps_host.o:24) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #14 '$t' in .bss(wwd_internal.o:9) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #50 '$t' in .bss(wwd_internal.o:10) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #120 '$t' in .bss(wwd_wifi.o:55) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #16 '$t' in .bss(netif.o:10) identifies code, but is in a section not marked as executable...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches tasks.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches dnsclient.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches mxchipWNET.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wifi.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches mxchipWNET.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches mxchipWNET.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches mxchipWNET.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches mxchipWNET.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches mxchipWNET.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches mxchipWNET.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches mxchipWNET.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wifimgr.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches dnsclient.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches ostimers.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches udp.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wwd_internal.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wwd_internal.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wwd_wifi.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss)...\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches netif.o(.bss).Not enough information to list image symbols.Not enough information to list the image map.Finished: 2 information, 43 warning and 37 error messages."..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf" - 37 Error(s), 59 Warning(s).Collection of Component include folders:  F:\MyProgram\xxx\Projects\STM32F429\demo\RVMDK\RTE  E:\WIN7\RealViewMDK5.18\Keil_v5\ARM\PACK\Keil\STM32F4xx_DFP\2.7.0\Drivers\CMSIS\Device\ST\STM32F4xx\IncludeCollection of Component Files used:Target not created.Build Time Elapsed:  00:02:06
发表于 2016-10-23 22:12:53 | 显示全部楼层
WIFI这个例程只能用5.15以下版本的编译器
发表于 2016-10-23 22:13:26 | 显示全部楼层
换个编译器,wifi例程要求只能是那个版本,这是mico的wifi库文件决定的
GMT+8, 2024-5-6 21:55 , Processed in 0.043257 second(s), 24 queries , Gzip On.
