大学生
最后登录1970-1-1
在线时间 小时
注册时间2014-6-4
现在我用硬件SPI,但配置的时候把火哥例程里面的CS引脚配置为复用推挽输出,SPI_InitStructure.SPI_NSS = SPI_NSS_Hard;但和软件SPI方式读出的数据不同,其实只是读了一个DeviceID,但读出的结果一直是255,软件模式下读出的是20,这是怎么回事 我配置的有问题吗?火哥哥。
void SPI_FLASH_Init(void)
SPI_InitTypeDef SPI_InitStructure;
/* Enable SPI1 and GPIO clocks */
/*!< SPI_FLASH_SPI_CS_GPIO, SPI_FLASH_SPI_MOSI_GPIO,
SPI_FLASH_SPI_MISO_GPIO, SPI_FLASH_SPI_DETECT_GPIO
and SPI_FLASH_SPI_SCK_GPIO Periph clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOD, ENABLE);
/*!< SPI_FLASH_SPI Periph clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
/*!< Configure SPI_FLASH_SPI pins: SCK */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
/*!< Configure SPI_FLASH_SPI pins: MISO */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
/*!< Configure SPI_FLASH_SPI pins: MOSI */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
/*!< Configure SPI_FLASH_SPI_CS_PIN pin: SPI_FLASH Card CS pin */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
/* Deselect the FLASH: Chip Select high */
/* SPI1 configuration */
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI1, &SPI_InitStructure);
/* Enable SPI1 */
SPI_Cmd(SPI1, ENABLE);
u32 SPI_FLASH_ReadDeviceID(void)
u32 Temp = 0;
/* Send "RDID " instruction */
SPI_FLASH_SendByte(W25X_DeviceID);
SPI_FLASH_SendByte(Dummy_Byte);
/* Read a byte from the FLASH */
Temp = SPI_FLASH_SendByte(Dummy_Byte);
return Temp;
USART1_Config();
SPI_FLASH_Init();
/* Get SPI Flash Device ID */
DeviceID = SPI_FLASH_ReadDeviceID();
Delay( 200 );
printf("The ID is %d\r\n", DeviceID);
while(1);
