查看: 11720|回复: 7
UART通信出错
发表于 2016-9-12 15:17:57 | 显示全部楼层 |阅读模式
         //初始化UART
         USARTx_Config();
        USART_SendData(USART1, 0x55);
       // 等待数据发送完毕
        while (USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
我这样写的串口发送,但是串口那边一直只收到“22”,无论发送的数据写啥,都是这样?
这是为啥呢?
发表于 2016-9-12 15:22:34 | 显示全部楼层
看着没有问题
 楼主| 发表于 2016-9-12 15:34:18 | 显示全部楼层
但是通信就是不对,数据发送的和收到的不对
发表于 2016-9-12 18:42:43 | 显示全部楼层
要看看你的串口初始化配置是怎样的
 楼主| 发表于 2016-9-12 19:41:05 | 显示全部楼层
随风 发表于 2016-9-12 18:42
要看看你的串口初始化配置是怎样的
void Usart1_Config()
GPIO_InitTypeDef Usart1_GPIO_Struct;
GPIO_InitTypeDef GPIO_Init_Struct;
USART_InitTypeDef Usart1_Struct;
//RCC_APB2PeriphClockCmd(USART_CLK,ENABLE);
RCC_APB1PeriphClockCmd(USART_CLK,ENABLE);
RCC_APB2PeriphClockCmd(USART_GPIO_CLK,ENABLE);
Usart1_GPIO_Struct.GPIO_Mode = GPIO_Mode_AF_PP;
Usart1_GPIO_Struct.GPIO_Pin = USART_TX_PIN;
Usart1_GPIO_Struct.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(USART_TX_PORT,&Usart1_GPIO_Struct);
Usart1_GPIO_Struct.GPIO_Mode = GPIO_Mode_IN_FLOATING;
Usart1_GPIO_Struct.GPIO_Pin = USART_RX_PIN;
GPIO_Init(USART_RX_PORT,&Usart1_GPIO_Struct);
Usart1_Struct.USART_BaudRate = USART_BAUD_RATE;
Usart1_Struct.USART_WordLength = USART_WordLength_8b;
Usart1_Struct.USART_StopBits = USART_StopBits_1;
Usart1_Struct.USART_Parity = USART_Parity_No;
Usart1_Struct.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
Usart1_Struct.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_Init(USARTx, &Usart1_Struct);
USART_Cmd(USARTx, ENABLE);
发表于 2016-9-12 20:02:23 | 显示全部楼层
看不出问题,检查下波特率是否一致
发表于 2016-9-12 20:40:14 | 显示全部楼层
烧个好的例程,试验一下硬件是否好坏;如果没问题再去修改你的代码吧。
发表于 2016-9-12 21:32:22 来自手机 | 显示全部楼层
有道理
GMT+8, 2024-9-21 02:47 , Processed in 0.030854 second(s), 23 queries , Gzip On.
