查看: 21526|回复: 1
如何设置三重ADC同步???
发表于 2017-3-4 20:40:14 | 显示全部楼层 |阅读模式
20火花
我设置了三重ADC同步,但是设置DMA_InitStructure.DMA_BufferSize = 3;,传完后就进入中断,但是它会连续进入两次中断,在调试中,只有第二次中断里面才把 DMA_ClearITPendingBit(DMA2_Stream0, DMA_IT_TCIF0);执行,清零,这是为什么呢???急!火哥???
* FILE                : adc.c
* DESCRIPTION         : --
* Author              : ysloveivy.
* Copyright           :
* History
* Rev                 : 0.00
* Date                : 2/20/2017
* create.
//------------------------ Include files ------------------------//
#include "..\FWlib\inc\stm32f4xx_adc.h"
#include "..\FWlib\inc\stm32f4xx_gpio.h"
#include "..\FWlib\inc\stm32f4xx_rcc.h"
#include "..\include\adc.h"
#include "..\include\usart.h"
//--------------------- Function Prototype ----------------------//
//static int initialize(void);
//static int read_adc(int);
__IO uint16_t ADC_ConvertedValue[3];
__IO uint16_t C=10;
//-------------------------- Variable ---------------------------//
static void ADC_GPIO_Config(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE);
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);
        //RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOF,ENABLE);
        //ADC2 GPIO Configuration PC3     ------> ADC2_IN 13
        //ADC3 GPIO Configuration PC1     ------> ADC3_IN 11
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_3;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;                                    //模拟输入
        //ADC1 GPIO Configuration PA2     ------> ADC1_IN 2
static void ADC_Mode_Config(void)
   ADC_InitTypeDef  ADC_InitStructure;
   ADC_CommonInitTypeDef  ADC_CommonInitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);                            //使能ADC1时钟
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC3, ENABLE);                            //使能ADC3时钟
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC2, ENABLE);                            //使能ADC2
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
        DMA_DeInit(DMA2_Stream0);
        DMA_InitStructure.DMA_PeripheralBaseAddr = CDR_ADDRESS;
        DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)ADC_ConvertedValue;
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable;
        DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
        DMA_InitStructure.DMA_Channel = DMA_Channel_0;
        DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  DMA_Cmd(DMA2_Stream0, ENABLE);
  ADC_CommonInitStructure.ADC_Mode = ADC_TripleMode_RegSimult;                        //ADC为独立模式
        ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;    //设置两个采样阶段之间的延迟周期数为5个周期
        ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1;         //DMA mode 1 enabled (2 / 3 half-words one by one - 1 then 2 then 3)
        ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;                     //ADCCLK=PCLK2/2=60/2=30;
        ADC_CommonInit(&ADC_CommonInitStructure);
        //DMA模式1:每发出一个DMA请求,就会传输一个表示ADC转换的数据项的半字,在三重ADC模式下,发出第一个请求时传输
        //ADC1的数据,发出第二个请求时传输ADC2的数据,发出第三个请求时传输ADC3的数据,重复此序列,DMA首先传输ADC1的数据
        //随后传输ADC2的数据,在传输ADC3的数据
        //初始化ADC
        ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;                          //ADC转换分辨率12位
        ADC_InitStructure.ADC_ScanConvMode = DISABLE;                                   //非扫描模式
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;                             //关闭连续转换模式
        ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;     //禁止触发检测
        //使用软件触发,外部触发不用配置,
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;                          //右对齐方式
        ADC_InitStructure.ADC_NbrOfConversion = 1;                                      //1个转换在规则序列中
        ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 1, ADC_SampleTime_480Cycles);
        ADC_Init(ADC2, &ADC_InitStructure);
        ADC_RegularChannelConfig(ADC2, ADC_Channel_13, 1, ADC_SampleTime_480Cycles);
        ADC_Init(ADC3, &ADC_InitStructure);
        ADC_RegularChannelConfig(ADC3, ADC_Channel_11, 1, ADC_SampleTime_480Cycles);
        ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);
    ADC_DMACmd(ADC1, ENABLE);
  ADC_Cmd(ADC1, ENABLE);
  ADC_Cmd(ADC2, ENABLE);
        ADC_Cmd(ADC3, ENABLE);
  NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream0_IRQn;
        DMA_ITConfig(DMA2_Stream0,DMA_IT_TC,ENABLE);//打开DMA传输完成中断
        // DMA_ClearFlag(DMA2_Stream0, DMA_FLAG_TCIF0);
        ADC_SoftwareStartConv(ADC1);
void ADC_DMA_Config(void)
        ADC_GPIO_Config();
  ADC_Mode_Config();
void DMA2_Stream0_IRQHandler(void)
  if(DMA_GetITStatus(DMA2_Stream0, DMA_IT_TCIF0)==SET)
           DMA_Cmd(DMA2_Stream0, DISABLE);
           RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, DISABLE);
           ADC_Cmd(ADC1, DISABLE);
           ADC->CCR &= ~ADC_CCR_DDS;
          C=C-1;
        //usart4.printf("\r\n The current AD value = 0x%08X \r\n", ADC_ConvertedValue[0]);
   // usart4.printf("\r\n The current AD value = 0x%08X \r\n", ADC_ConvertedValue[1]);
        //usart4.printf("\r\n The current AD value = %f V \r\n", (float)((uint16_t)ADC_ConvertedValue[1]*2.5/4096));
   // usart4.printf("\r\n The current AD value = 0x%08X \r\n", ADC_ConvertedValue[2]);
        // ADC_Cmd(ADC1, DISABLE);
   // ADC_Cmd(ADC2, DISABLE);
        // ADC_Cmd(ADC3, DISABLE);
         // RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, DISABLE);
                //DMA_Cmd(DMA2_Stream0, DISABLE);
发表于 2017-3-6 09:07:07 | 显示全部楼层
帮顶,只能自己好好研究下了。
GMT+8, 2024-11-26 03:30 , Processed in 0.028016 second(s), 22 queries , Gzip On.
