查看: 14934|回复: 11
求助429的6540摄像头中这些宏
发表于 2017-4-10 23:19:37 | 显示全部楼层 |阅读模式
  1. /////////////////下面的这些宏定义有什么作用,请大神指教!!!//////////////////////////////////////////////////////
  2. /* OV5640 Registers definition when DSP bank selected (0xFF = 0x00) */
  3. #define OV5640_DSP_R_BYPASS     0x05
  4. #define OV5640_DSP_Qs           0x44
  5. #define OV5640_DSP_CTRL         0x50
  6. #define OV5640_DSP_HSIZE1       0x51
  7. #define OV5640_DSP_VSIZE1       0x52
  8. #define OV5640_DSP_XOFFL        0x53
  9. #define OV5640_DSP_YOFFL        0x54
  10. #define OV5640_DSP_VHYX         0x55
  11. #define OV5640_DSP_DPRP         0x56
  12. #define OV5640_DSP_TEST         0x57
  13. #define OV5640_DSP_ZMOW         0x5A
  14. #define OV5640_DSP_ZMOH         0x5B
  15. #define OV5640_DSP_ZMHH         0x5C
  16. #define OV5640_DSP_BPADDR       0x7C
  17. #define OV5640_DSP_BPDATA       0x7D
  18. #define OV5640_DSP_CTRL2        0x86
  19. #define OV5640_DSP_CTRL3        0x87
  20. #define OV5640_DSP_SIZEL        0x8C
  21. #define OV5640_DSP_HSIZE2       0xC0
  22. #define OV5640_DSP_VSIZE2       0xC1
  23. #define OV5640_DSP_CTRL0        0xC2
  24. #define OV5640_DSP_CTRL1        0xC3
  25. #define OV5640_DSP_R_DVP_SP     0xD3
  26. #define OV5640_DSP_IMAGE_MODE   0xDA
  27. #define OV5640_DSP_RESET        0xE0
  28. #define OV5640_DSP_MS_SP        0xF0
  29. #define OV5640_DSP_SS_ID        0x7F
  30. #define OV5640_DSP_SS_CTRL      0xF8
  31. #define OV5640_DSP_MC_BIST      0xF9
  32. #define OV5640_DSP_MC_AL        0xFA
  33. #define OV5640_DSP_MC_AH        0xFB
  34. #define OV5640_DSP_MC_D         0xFC
  35. #define OV5640_DSP_P_STATUS     0xFE
  36. #define OV5640_DSP_RA_DLMT      0xFF
  37. /////////////////框起来的是暂时看不懂的//////////////////////////////////////////////////////
  38. /////////////////框起来的是暂时看不懂的//////////////////////////////////////////////////////
  39. /* OV5640 Registers definition when sensor bank selected (0xFF = 0x01) */
  40. #define OV5640_SENSOR_GAIN       0x00
  41. #define OV5640_SENSOR_COM1       0x03
  42. #define OV5640_SENSOR_REG04      0x04
  43. #define OV5640_SENSOR_REG08      0x08
  44. #define OV5640_SENSOR_COM2       0x09
  45. #define OV5640_SENSOR_PIDH       0x300A
  46. #define OV5640_SENSOR_PIDL       0x300B
  47. #define OV5640_SENSOR_COM3       0x0C
  48. #define OV5640_SENSOR_COM4       0x0D
  49. #define OV5640_SENSOR_AEC        0x10
  50. #define OV5640_SENSOR_CLKRC      0x11
  51. #define OV5640_SENSOR_COM7       0x12
  52. #define OV5640_SENSOR_COM8       0x13
  53. #define OV5640_SENSOR_COM9       0x14
  54. #define OV5640_SENSOR_COM10      0x15
  55. #define OV5640_SENSOR_HREFST     0x17
  56. #define OV5640_SENSOR_HREFEND    0x18
  57. #define OV5640_SENSOR_VSTART     0x19
  58. #define OV5640_SENSOR_VEND       0x1A
  59. #define OV5640_SENSOR_MIDH       0x1C
  60. #define OV5640_SENSOR_MIDL       0x1D
  61.
  62. #define OV5640_SENSOR_AEW        0x24
  63. #define OV5640_SENSOR_AEB        0x25
  64. #define OV5640_SENSOR_W          0x26
  65. #define OV5640_SENSOR_REG2A      0x2A
  66. #define OV5640_SENSOR_FRARL      0x2B
  67. #define OV5640_SENSOR_ADDVSL     0x2D
  68. #define OV5640_SENSOR_ADDVHS     0x2E
  69. #define OV5640_SENSOR_YAVG       0x2F
  70. #define OV5640_SENSOR_REG32      0x32
  71. #define OV5640_SENSOR_ARCOM2     0x34
  72. #define OV5640_SENSOR_REG45      0x45
  73. #define OV5640_SENSOR_FLL        0x46
  74. #define OV5640_SENSOR_FLH        0x47
  75. #define OV5640_SENSOR_COM19      0x48
  76. #define OV5640_SENSOR_ZOOMS      0x49
  77. #define OV5640_SENSOR_COM22      0x4B
  78. #define OV5640_SENSOR_COM25      0x4E
  79. #define OV5640_SENSOR_BD50       0x4F
  80. #define OV5640_SENSOR_BD60       0x50
  81. #define OV5640_SENSOR_REG5D      0x5D
  82. #define OV5640_SENSOR_REG5E      0x5E
  83. #define OV5640_SENSOR_REG5F      0x5F
  84. #define OV5640_SENSOR_REG60      0x60
  85. #define OV5640_SENSOR_HISTO_LOW  0x61
  86. #define OV5640_SENSOR_HISTO_HIGH 0x62
刚学到这个摄像头,看了好久,头都大了,请大神指点一下,谢谢啦。
发表于 2017-4-11 08:47:23 | 显示全部楼层
/* OV5640 Registers definition when DSP bank selected (0xFF = 0x00) */OV5640的寄存器定义
发表于 2017-4-11 09:12:07 | 显示全部楼层
寄存器地址,看ov5640的datasheet
 楼主| 发表于 2017-4-11 11:04:50 | 显示全部楼层
火哥,这部分内容好打脑壳哦
 楼主| 发表于 2017-4-11 11:06:56 | 显示全部楼层
429的DMCI接口都很简单,就是6540这模组的寄存器等非常的繁琐
发表于 2017-4-11 12:25:12 | 显示全部楼层
这些一般用厂家配置,不用研究它啦
 楼主| 发表于 2017-4-11 14:15:48 | 显示全部楼层
flyleaf 发表于 2017-4-11 12:25
这些一般用厂家配置,不用研究它啦
嗯的,今天继续研究这摄像头
 楼主| 发表于 2017-4-11 14:19:47 | 显示全部楼层
这些一般用厂家配置,不用研究它啦
下面的这一部分代码是厂家提供用来的自动处理摄像头吧??
  1. unsigned short RGB565_Init[][2]=
  2. {
  3.     //15fps VGA RGB565 output
  4.     // 24MHz input clock, 24MHz PCLK
  5.     0x3103, 0x11, // system clock from pad, bit[1]
  6.     0x3008, 0x82, // software reset, bit[7]
  7.     // delay 5ms
  8.     0x3008, 0x42, // software power down, bit[6]
  9.     0x3103, 0x03, // system clock from PLL, bit[1]
  10.     0x3017, 0xff, // FREX, Vsync, HREF, PCLK, D[9:6] output enable
  11.     0x3018, 0xff, // D[5:0], GPIO[1:0] output enable
  12.     0x3034, 0x1a, // MIPI 10-bit
  13.     0x3037, 0x13, // PLL root divider, bit[4], PLL pre-divider, bit[3:0]
  14.     0x3108, 0x01, // PCLK root divider, bit[5:4], SCLK2x root divider, bit[3:2]
  15.     // SCLK root divider, bit[1:0]
  16.     0x3630, 0x36,
  17.     0x3631, 0x0e,
  18.     0x3632, 0xe2,
  19.     0x3633, 0x12,
  20.     0x3621, 0xe0,
  21.     0x3704, 0xa0,
  22.     0x3703, 0x5a,
  23.     0x3715, 0x78,
  24.     0x3717, 0x01,
  25.     0x370b, 0x60,
  26.     0x3705, 0x1a,
  27.     0x3905, 0x02,
  28.     0x3906, 0x10,
  29.     0x3901, 0x0a,
  30.     0x3731, 0x12,
  31.     0x3600, 0x08, // VCM control
  32.     0x3601, 0x33, // VCM control
  33.     0x302d, 0x60, // system control
  34.     0x3620, 0x52,
  35.     0x371b, 0x20,
  36.     0x471c, 0x50,
  37.     0x3a13, 0x43, // pre-gain = 1.047x
  38.     0x3a18, 0x00, // gain ceiling
  39.     0x3a19, 0xf8, // gain ceiling = 15.5x
  40.     0x3635, 0x13,
  41.     0x3636, 0x03,
  42.     0x3634, 0x40,
  43.     0x3622, 0x01,
  44.     // 50/60Hz detection 50/60Hz 灯光条纹过滤
  45.     0x3c01, 0x34, // Band auto, bit[7]
  46.     0x3c04, 0x28, // threshold low sum
  47.     0x3c05, 0x98, // threshold high sum
  48.     0x3c06, 0x00, // light meter 1 threshold[15:8]
  49.     0x3c07, 0x08, // light meter 1 threshold[7:0]
  50.     0x3c08, 0x00, // light meter 2 threshold[15:8]
  51.     0x3c09, 0x1c, // light meter 2 threshold[7:0]
  52.     0x3c0a, 0x9c, // sample number[15:8]
  53.     0x3c0b, 0x40, // sample number[7:0]
  54.     0x3810, 0x00, // Timing Hoffset[11:8]
  55.     0x3811, 0x10, // Timing Hoffset[7:0]
  56.     0x3812, 0x00, // Timing Voffset[10:8]
  57.     0x3708, 0x64,
  58.     0x4001, 0x02, // BLC start from line 2
  59.     0x4005, 0x1a, // BLC always update
  60.     0x3000, 0x00, // enable blocks
  61.     0x3004, 0xff, // enable clocks
  62.     0x300e, 0x58, // MIPI power down, DVP enable
  63.     0x302e, 0x00,
  64.     0x4300, 0x6f, // RGB565
  65.     0x501f, 0x01, // RGB565
  66.     0x440e, 0x00,
  67.     0x5000, 0xa7, // Lenc on, raw gamma on, BPC on, WPC on, CIP on
  68.     // AEC target 自动曝光控制
  69.     0x3a0f, 0x30, // stable range in high
  70.     0x3a10, 0x28, // stable range in low
  71.     0x3a1b, 0x30, // stable range out high
  72.     0x3a1e, 0x26, // stable range out low
  73.     0x3a11, 0x60, // fast zone high
  74.     0x3a1f, 0x14, // fast zone low
  75.     // Lens correction for ? 镜头补偿
  76.     0x5800, 0x23,
  77.     0x5801, 0x14,
  78.     0x5802, 0x0f,
  79.     0x5803, 0x0f,
  80.     0x5804, 0x12,
  81.     0x5805, 0x26,
  82.     0x5806, 0x0c,
  83.     0x5807, 0x08,
  84.     0x5808, 0x05,
  85.     0x5809, 0x05,
  86.     0x580a, 0x08,
  87.     0x580b, 0x0d,
  88.     0x580c, 0x08,
  89.     0x580d, 0x03,
  90.     0x580e, 0x00,
  91.     0x580f, 0x00,
  92.     0x5810, 0x03,
  93.     0x5811, 0x09,
  94.     0x5812, 0x07,
  95.     0x5813, 0x03,
  96.     0x5814, 0x00,
  97.     0x5815, 0x01,
  98.     0x5816, 0x03,
  99.     0x5817, 0x08,
  100.     0x5818, 0x0d,
  101.     0x5819, 0x08,
  102.     0x581a, 0x05,
  103.     0x581b, 0x06,
  104.     0x581c, 0x08,
  105.     0x581d, 0x0e,
  106.     0x581e, 0x29,
  107.     0x581f, 0x17,
  108.     0x5820, 0x11,
  109.     0x5821, 0x11,
  110.     0x5822, 0x15,
  111.     0x5823, 0x28,
  112.     0x5824, 0x46,
  113.     0x5825, 0x26,
  114.     0x5826, 0x08,
  115.     0x5827, 0x26,
  116.     0x5828, 0x64,
  117.     0x5829, 0x26,
  118.     0x582a, 0x24,
  119.     0x582b, 0x22,
  120.     0x582c, 0x24,
  121.     0x582d, 0x24,
  122.     0x582e, 0x06,
  123.     0x582f, 0x22,
  124.     0x5830, 0x40,
  125.     0x5831, 0x42,
  126.     0x5832, 0x24,
  127.     0x5833, 0x26,
  128.     0x5834, 0x24,
  129.     0x5835, 0x22,
  130.     0x5836, 0x22,
  131.     0x5837, 0x26,
  132.     0x5838, 0x44,
  133.     0x5839, 0x24,
  134.     0x583a, 0x26,
  135.     0x583b, 0x28,
  136.     0x583c, 0x42,
  137.     0x583d, 0xce, // lenc BR offset
  138.     // AWB 自动白平衡
  139.     0x5180, 0xff, // AWB B block
  140.     0x5181, 0xf2, // AWB control
  141.     0x5182, 0x00, // [7:4] max local counter, [3:0] max fast counter
  142.     0x5183, 0x14, // AWB advanced
  143.     0x5184, 0x25,
  144.     0x5185, 0x24,
  145.     0x5186, 0x09,
  146.     0x5187, 0x09,
  147.     0x5188, 0x09,
  148.     0x5189, 0x75,
  149.     0x518a, 0x54,
  150.     0x518b, 0xe0,
  151.     0x518c, 0xb2,
  152.     0x518d, 0x42,
  153.     0x518e, 0x3d,
  154.     0x518f, 0x56,
  155.     0x5190, 0x46,
  156.     0x5191, 0xf8, // AWB top limit
  157.     0x5192, 0x04, // AWB bottom limit
  158.     0x5193, 0x70, // red limit
  159.     0x5194, 0xf0, // green limit
  160.     0x5195, 0xf0, // blue limit
  161.     0x5196, 0x03, // AWB control
  162.     0x5197, 0x01, // local limit
  163.     0x5198, 0x04,
  164.     0x5199, 0x12,
  165.     0x519a, 0x04,
  166.     0x519b, 0x00,
  167.     0x519c, 0x06,
  168.     0x519d, 0x82,
  169.     0x519e, 0x38, // AWB control
  170.     // Gamma 伽玛曲线
  171.     0x5480, 0x01, // Gamma bias plus on, bit[0]
  172.     0x5481, 0x08,
  173.     0x5482, 0x14,
  174.     0x5483, 0x28,
  175.     0x5484, 0x51,
  176.     0x5485, 0x65,
  177.     0x5486, 0x71,
  178.     0x5487, 0x7d,
  179.     0x5488, 0x87,
  180.     0x5489, 0x91,
  181.     0x548a, 0x9a,
  182.     0x548b, 0xaa,
  183.     0x548c, 0xb8,
  184.     0x548d, 0xcd,
  185.     0x548e, 0xdd,
  186.     0x548f, 0xea,
  187.     0x5490, 0x1d,
  188.     // color matrix 色彩矩阵
  189.     0x5381, 0x1e, // CMX1 for Y
  190.     0x5382, 0x5b, // CMX2 for Y
  191.     0x5383, 0x08, // CMX3 for Y
  192.     0x5384, 0x0a, // CMX4 for U
  193.     0x5385, 0x7e, // CMX5 for U
  194.     0x5386, 0x88, // CMX6 for U
  195.     0x5387, 0x7c, // CMX7 for V
  196.     0x5388, 0x6c, // CMX8 for V
  197.     0x5389, 0x10, // CMX9 for V
  198.     0x538a, 0x01, // sign[9]
  199.     0x538b, 0x98, // sign[8:1]
  200.     // UV adjust UV 色彩饱和度调整
  201.     0x5580, 0x06, // saturation on, bit[1]
  202.     0x5583, 0x40,
  203.     0x5584, 0x10,
  204.     0x5589, 0x10,
  205.     0x558a, 0x00,
  206.     0x558b, 0xf8,
  207.     0x501d, 0x40, // enable manual offset of contrast
  208.     // CIP 锐化和降噪
  209.     0x5300, 0x08, // CIP sharpen MT threshold 1
  210.     0x5301, 0x30, // CIP sharpen MT threshold 2
  211.     0x5302, 0x10, // CIP sharpen MT offset 1
  212.     0x5303, 0x00, // CIP sharpen MT offset 2
  213.     0x5304, 0x08, // CIP DNS threshold 1
  214.     0x5305, 0x30, // CIP DNS threshold 2
  215.     0x5306, 0x08, // CIP DNS offset 1
  216.     0x5307, 0x16, // CIP DNS offset 2
  217.     0x5309, 0x08, // CIP sharpen TH threshold 1
  218.     0x530a, 0x30, // CIP sharpen TH threshold 2
  219.     0x530b, 0x04, // CIP sharpen TH offset 1
  220.     0x530c, 0x06, // CIP sharpen TH offset 2
  221.     0x5025, 0x00,
  222.     0x3008, 0x02, // wake up from standby, bit[6]
  223.
  224. //    0x503d, 0x80,//测试彩条
  225. //    0x4741, 0x00,
  226. };
的吧
发表于 2017-4-11 14:44:28 | 显示全部楼层
的吧
是的,要研究的话就一个个对手册来查
 楼主| 发表于 2017-4-11 14:48:45 | 显示全部楼层
flyleaf 发表于 2017-4-11 14:44
是的,要研究的话就一个个对手册来查
昨天看一天英文手册了,感觉英语水平都提升了
发表于 2017-4-11 14:53:44 | 显示全部楼层
当年我的6级就是看文档看来的
 楼主| 发表于 2017-4-11 23:34:01 | 显示全部楼层
flyleaf 发表于 2017-4-11 14:53
当年我的6级就是看文档看来的
GMT+8, 2025-1-16 00:20 , Processed in 0.031998 second(s), 23 queries , Gzip On.
