查看: 11300|回复: 4
配套程序里MPU6050采集数据用的是硬件IIC还是模拟的
发表于 2017-5-16 22:29:58 | 显示全部楼层 |阅读模式
本人新手菜鸟,跟网上的对比半天看不出来,所以请教大家。
发表于 2017-5-17 15:44:42 | 显示全部楼层
有硬件有软件的,看看iic.c文件的驱动,有初始化硬件外设就是硬件iic
 楼主| 发表于 2017-5-17 16:51:30 | 显示全部楼层
多谢回复,我看视频里是有两套程序,不过光盘里的源码对6050的基本数据采集只有一个工程。iic.c里第一个函数是这个,这是初始化硬件吗?不好意思我不太懂,麻烦了。
/*******************************  Function ************************************/
  * @brief  初始化I2C总线,使用I2C前需要调用
  * @param  无
  * @retval 无
void I2cMaster_Init(void)
  I2C_InitTypeDef I2C_InitStructure;
    /* Enable I2Cx clock */
  RCC_APB1PeriphClockCmd(SENSORS_I2C_RCC_CLK, ENABLE);
  /* Enable I2C GPIO clock */
  RCC_AHB1PeriphClockCmd(SENSORS_I2C_SCL_GPIO_CLK | SENSORS_I2C_SDA_GPIO_CLK, ENABLE);
  /* Configure I2Cx pin: SCL ----------------------------------------*/
  GPIO_InitStructure.GPIO_Pin =  SENSORS_I2C_SCL_GPIO_PIN;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
  /* Connect pins to Periph */
  GPIO_PinAFConfig(SENSORS_I2C_SCL_GPIO_PORT, SENSORS_I2C_SCL_GPIO_PINSOURCE, SENSORS_I2C_AF);
  GPIO_Init(SENSORS_I2C_SCL_GPIO_PORT, &GPIO_InitStructure);
  /* Configure I2Cx pin: SDA ----------------------------------------*/
  GPIO_InitStructure.GPIO_Pin = SENSORS_I2C_SDA_GPIO_PIN;
  GPIO_PinAFConfig(SENSORS_I2C_SDA_GPIO_PORT, SENSORS_I2C_SDA_GPIO_PINSOURCE, SENSORS_I2C_AF);
  GPIO_Init(SENSORS_I2C_SDA_GPIO_PORT, &GPIO_InitStructure);
  I2C_DeInit(SENSORS_I2C);
  I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
  I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
  I2C_InitStructure.I2C_OwnAddress1 = I2C_OWN_ADDRESS;
  I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
  I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
  I2C_InitStructure.I2C_ClockSpeed = I2C_SPEED;
  /* Enable the I2C peripheral */
  I2C_Cmd(SENSORS_I2C, ENABLE);
  /* Initialize the I2C peripheral */
  I2C_Init(SENSORS_I2C, &I2C_InitStructure);
  return;
发表于 2017-5-17 17:11:27 | 显示全部楼层
是的,这部分是硬件iic初始化
 楼主| 发表于 2017-5-17 18:55:16 | 显示全部楼层
flyleaf 发表于 2017-5-17 17:11
是的,这部分是硬件iic初始化
好的,懂了,非常感谢!
GMT+8, 2024-11-22 21:17 , Processed in 0.040502 second(s), 24 queries , Gzip On.
