查看: 9175|回复: 2
F429 编码器计数问题
发表于 2017-8-24 17:31:55 | 显示全部楼层 |阅读模式
最近在使用F429的编码器模式,从网上找了好多资料,感觉结果并不理想,电机买的是平衡小车之家的49那款,AB项编码器.
发现 TIM_EncoderInterfaceConfig(TIM1, TIM_EncoderMode_TI12,TIM_ICPolarity_Rising, TIM_ICPolarity_Rising)函数 ;后面2个参数配置为TIM_ICPolarity_Rising或者TIM_ICPolarity_Falling,转动电机编码盘,计数器基本无变化,0,1之间抖动。 设置为TIM_ICPolarity_BothEdge后,可以计数, 但该库函数,标准的值里没有TIM_ICPolarity_BothEdge 这个选项。不理解啊,还请各位看下。小弟只想在上升沿读取编码器的值。该如何配置?
附上部分代码
完整的有点大,发不上来
//  编码器的配置代码
void Encoder_Config(void)
        TIM_ICInitTypeDef TIM_ICInitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);
        TIM_DeInit(TIM1);
        TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
        TIM_TimeBaseStructure.TIM_Period = 10000;
        TIM_TimeBaseStructure.TIM_Prescaler = 0x0;
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
        TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
//        NVIC_choice(1);                                        //不开中断
        TIM_EncoderInterfaceConfig(TIM1, TIM_EncoderMode_TI12,TIM_ICPolarity_Rising, TIM_ICPolarity_Rising);  //TIM_ICPolarity_Rising   TIM_ICPolarity_BothEdge   éÏéyÑØ2¶»ñ
        TIM_ICStructInit(&TIM_ICInitStructure);
        TIM_ICInitStructure.TIM_ICFilter = 0;//ÂË2¨
        TIM_ICInit(TIM1,&TIM_ICInitStructure);
        //TIM_ClearFlag(encoder_TIM,TIM_FLAG_Update);                                        //清除TIM1标记,不开中断,未使用
        //TIM_ITConfig(encoder_TIM,TIM_IT_Update,ENABLE);                        //使能TIM1中断
  TIM_SetCounter(TIM1,0);        //设置计数器的值为0
  TIM_Cmd(TIM1, ENABLE);        //启用TIM2
//编码器的配置代码
void Encoder_GpioConfig(void)
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE);
        GPIO_StructInit(&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Speed = GPIO_High_Speed;
        GPIO_Init(GPIOA,&GPIO_InitStructure);
        GPIO_Init(GPIOC,&GPIO_InitStructure);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_TIM1);
        GPIO_PinAFConfig(GPIOC,GPIO_PinSource9,GPIO_AF_TIM1);
void delay(uint32_t delay)
        for( ; delay !=0 ; delay--);
        int value = 0;
        int fx = 0;
        Debug_USART_Config();                ////配置串口
        Encoder_GpioConfig();          //配置编码器GPIO
        Encoder_Config();                                //配置编码器
        LED_GPIO_Config();                        //LED配置
        GPIO_Configuration();                //GPIO配置,高电平让电机转动
        GPIO_SetBits(GPIO_PIN_IN1_2_PORT,GPIO_PIN_IN2);                //使电机转动
                                printf("计数值 = %d  \n",Encoder_Val);                                // Encoder 为 TIM1->CR1
                                delay(100000);
发表于 2017-8-25 09:09:59 | 显示全部楼层
没有用过这功能
 楼主| 发表于 2017-8-25 10:21:38 | 显示全部楼层
有木有懂得?好多天了。不知道哪儿的问题啊
GMT+8, 2024-11-23 12:07 , Processed in 0.040754 second(s), 24 queries , Gzip On.
