查看: 12132|回复: 6
按键中断——新人求教
发表于 2018-7-21 10:25:09 | 显示全部楼层 |阅读模式
编写了一段程序,通过中断的方式让K1,K2控制LED的亮灭,但是K1有效,K2无反应,下面是程序
 楼主| 发表于 2018-7-21 10:25:35 | 显示全部楼层
#include "stm32f10x.h"  //相当于51单片机中的 #include<reg51.h>
#include "bsp_led.h"
#include "bsp_exti.h"
void Delay(uint32_t count)
        for(;count!=0;count--);
        //系统的时钟已经被配置成72M
        LED_GPIO_Config();
        EXTI_Key_Config();
 楼主| 发表于 2018-7-21 10:26:33 | 显示全部楼层
static void EXTI_NVIC_Config(void)
        NVIC_InitTypeDef NVIC_InitStruct;
        NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority=1;
        NVIC_InitStruct.NVIC_IRQChannelSubPriority=1;
        NVIC_InitStruct.NVIC_IRQChannelCmd=ENABLE;
        //K1
        NVIC_InitStruct.NVIC_IRQChannel=EXTI0_IRQn;
        NVIC_Init(&NVIC_InitStruct);
        //K2
        NVIC_InitStruct.NVIC_IRQChannel=EXTI15_10_IRQn;
void EXTI_Key_Config(void)
        EXTI_InitTypeDef EXTI_InitStruct;
        //配置中断优先级
        EXTI_NVIC_Config();
        //初始化按键K1、K2
        RCC_APB2PeriphClockCmd(KEY1_INT_GPIO_CLK,ENABLE);
        GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        GPIO_InitStruct.GPIO_Pin = KEY1_INT_GPIO_PIN;
        GPIO_Init(KEY1_INT_GPIO_PORT,&GPIO_InitStruct);
        //初始化EXTI
        //K1
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
        GPIO_EXTILineConfig(GPIO_PortSourceGPIOA,GPIO_PinSource0);
        EXTI_InitStruct.EXTI_Line=EXTI_Line0;
        EXTI_InitStruct.EXTI_Mode=EXTI_Mode_Interrupt;
        EXTI_InitStruct.EXTI_Trigger=EXTI_Trigger_Rising;
        EXTI_InitStruct.EXTI_LineCmd=ENABLE;
        EXTI_Init(&EXTI_InitStruct);
        //K2
        GPIO_InitStruct.GPIO_Pin = KEY2_INT_GPIO_PIN;
        GPIO_Init(KEY2_INT_GPIO_PORT,&GPIO_InitStruct);
        GPIO_EXTILineConfig(GPIO_PortSourceGPIOC,GPIO_PinSource13);
        EXTI_InitStruct.EXTI_Line=EXTI_Line13;
        EXTI_InitStruct.EXTI_Trigger=EXTI_Trigger_Falling;
 楼主| 发表于 2018-7-21 10:26:57 | 显示全部楼层
#ifndef _BSP_EXTI_H
#define _BSP_EXTI_H
#define KEY1_INT_GPIO_PORT                                GPIOA
#define KEY1_INT_GPIO_CLK                                        RCC_APB2Periph_GPIOA
#define KEY1_INT_GPIO_PIN                                        GPIO_Pin_0
#define KEY2_INT_GPIO_PORT                                GPIOC
#define KEY2_INT_GPIO_CLK                                        RCC_APB2Periph_GPIOC
#define KEY2_INT_GPIO_PIN                                        GPIO_Pin_13
void EXTI_Key_Config(void);
#endif /*_BSP_EXTI_H*/
 楼主| 发表于 2018-7-21 10:27:25 | 显示全部楼层
void EXTI0_IRQHandler(void)
        if(EXTI_GetITStatus(EXTI_Line0)!=RESET)
                LED_TOGGLE;
        EXTI_ClearITPendingBit(EXTI_Line0);
void EXTI13_IRQHandler(void)
        if(EXTI_GetITStatus(EXTI_Line13)!=RESET)
                LED_TOGGLE;
        EXTI_ClearITPendingBit(EXTI_Line13);
发表于 2018-7-21 11:04:40 | 显示全部楼层
key2的中断服务函数不是EXTI13,是EXTI15_10_合在一起的
回复 支持 1 反对 0
 楼主| 发表于 2018-7-21 15:44:09 | 显示全部楼层
谢谢热心的大佬
GMT+8, 2025-12-14 20:59 , Processed in 0.057997 second(s), 23 queries , Gzip On.
