查看: 618|回复: 1
STM32标准库DMA SRAM到串口程序问题
发表于 2024-6-28 15:48:13 | 显示全部楼层 |阅读模式
请问下,在STM32标准库视频DMA一章,数据从SRAM到外设(串口),使能DMA时钟时,为什么示例程序里是RCC_AHBPeripheralClockCmd(USART_TX_DMA_CLK,ENABLE),而不是USART_RX_DMA_CLK呢?
// Memory -> P (USART->DR)
void USARTx_DMA_Config(void)
        DMA_InitTypeDef DMA_InitStruct;
        RCC_AHBPeriphClockCmd(USART_TX_DMA_CLK, ENABLE);
        DMA_InitStruct.DMA_PeripheralBaseAddr = (uint32_t)USART_DR_ADDRESS;
        DMA_InitStruct.DMA_MemoryBaseAddr = (uint32_t)SendBuff;
        DMA_InitStruct.DMA_DIR = DMA_DIR_PeripheralDST;
        DMA_InitStruct.DMA_BufferSize = SENDBUFF_SIZE;
        DMA_InitStruct.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
        DMA_InitStruct.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
        DMA_InitStruct.DMA_MemoryInc = DMA_MemoryInc_Enable;
        DMA_InitStruct.DMA_MemoryDataSize = DMA_PeripheralDataSize_Byte;
        DMA_InitStruct.DMA_Mode = DMA_Mode_Normal;
        DMA_InitStruct.DMA_Priority = DMA_Priority_High;
        DMA_InitStruct.DMA_M2M = DMA_M2M_Disable;
        DMA_Init(USART_TX_DMA_CHANNEL, &DMA_InitStruct);
        DMA_ClearFlag(USART_TX_DMA_FLAG_TC);
        DMA_Cmd(USART_TX_DMA_CHANNEL, ENABLE);
发表于 2024-7-1 09:19:56 | 显示全部楼层
你是要将数据发送出去,所以是TX,而RX是接收数据使用
GMT+8, 2024-11-23 06:43 , Processed in 0.106905 second(s), 24 queries , Gzip On.
