查看: 23665|回复: 2
STM32 4*6矩阵按键程序求教
发表于 2014-5-8 12:33:45 | 显示全部楼层 |阅读模式
这是矩阵程序(参考吴坚鸿的按键程序)是从51上面移植过来的,在51上面运行正常,但在STM32上没有反应,主要表现在按键扫描函数Key_Scan里面 switch的case1 执行完之后,直接跳转到case9,请大虾帮忙看看,谢了~
/*key.h文件*/
#ifndef __KEY_H
#define __KEY_H
#include "sys.h"
#include "delay.h"
#include "12864.h"
#include "usart.h"
#include "led.h"
#define key_sr1 PDin(4)
#define key_sr2 PDin(5)
#define key_sr3 PDin(8)
#define key_sr4 PDin(9)
#define         key_sr1  GPIO_ReadInputDataBit(GPIOD,GPIO_Pin_4)//读取按键
#define         key_sr2  GPIO_ReadInputDataBit(GPIOD,GPIO_Pin_5)//
#define         key_sr3  GPIO_ReadInputDataBit(GPIOD,GPIO_Pin_8)//
#define         key_sr4  GPIO_ReadInputDataBit(GPIOD,GPIO_Pin_9)//
#define         key_dr1  PEout(10)
#define         key_dr2  PEout(11) //
#define         key_dr3  PEout(12)        //
#define         key_dr4  PEout(13)        //
#define         key_dr5  PEout(14)        //
#define         key_dr6  PEout(15)
#define   const_voice_short   100    //
#define   const_key_time      20    //
void KEY_Init(void);
void KEY_Scan(void);
void key_service(void);
extern u16 uiVoiceCnt;
extern u8  ucKeySec;
#endif
/*key.c文件*/
#include "key.h"
//IO初始化
void KEY_Init(void) //IO³õʼ»¯
        //KEY0-->GPIOA.13,KEY1-->GPIOA.15  上拉输入
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOE,ENABLE);
        GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9;//PE2~4
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_Init(GPIOD, &GPIO_InitStructure);//³õʼ»¯GPIOD4,5,8,9
        //GPIO_SetBits(GPIOD,GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9);
        GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
        GPIO_Init(GPIOE, &GPIO_InitStructure);//
        GPIO_SetBits(GPIOE,GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15);
u16 uiVoiceCnt=0;  //
u8 ucKeySec = 0;   //
u8  ucKeyStep = 1; //
u8  ucKeyLock = 0; //
u16 uiKeyTimeCnt = 0;
void KEY_Scan()
        //LED0 = 0;
        switch(ucKeyStep)
                case 1:   //
                        key_dr1=0;
                        key_dr2=1;
                        key_dr3=1;
                        key_dr4=1;
                        key_dr5=1;
                        key_dr6=1;
                        uiKeyTimeCnt=0;  //
                        ucKeyStep++;     //
                        break;
                case 2:    //
                        uiKeyTimeCnt++;
                        if(uiKeyTimeCnt>2)
                                uiKeyTimeCnt=0;
                                ucKeyStep++;     //
                        break;
                case 3:
                        if(key_sr1==1&&key_sr2==1&&key_sr3==1&&key_sr4==1)
                                ucKeyStep++;  //
                                ucKeyLock=0;  //
                                uiKeyTimeCnt=0; //
                        else if(ucKeyLock==0)
                                if(key_sr1==0&&key_sr2==1&&key_sr3==1&&key_sr4==1)
                                        uiKeyTimeCnt++;  //
                                        if(uiKeyTimeCnt>const_key_time)
                                                uiKeyTimeCnt=0;
                                                ucKeyLock=1; //
                                                ucKeySec=1;  //
                                else if(key_sr1==1&&key_sr2==0&&key_sr3==1&&key_sr4==1)
                                        uiKeyTimeCnt++;  //
                                                uiKeyTimeCnt=0;
                                                ucKeyLock=1;//
                                                ucKeySec=2;  //
                                else if(key_sr1==1&&key_sr2==1&&key_sr3==0&&key_sr4==1)
                                        uiKeyTimeCnt++;  //
                                                uiKeyTimeCnt=0;
                                                ucKeyLock=1; //
                                                ucKeySec=3;  //
                                else if(key_sr1==1&&key_sr2==1&&key_sr3==1&&key_sr4==0)
                                        uiKeyTimeCnt++;  //????????
                                                uiKeyTimeCnt=0;
                                                ucKeyLock=1;//??????,??????,??????,?????????
                                                ucKeySec=4;  //??4??
                        break;
                case 4:   //????????????
                        key_dr1=1;
                        key_dr2=0;
                        key_dr3=1;
                        key_dr4=1;
                        key_dr5=1;
                        key_dr6=1;
                        uiKeyTimeCnt=0;  //???????
                        ucKeyStep++;     //??????????
                        break;
                case 5:     //???????????????????,????????????????
                        uiKeyTimeCnt++;
                        if(uiKeyTimeCnt>1)
                                uiKeyTimeCnt=0;
                        break;
                case 6:
                                ucKeyStep++;  //????????,??????????
                                ucKeyLock=0;  //????????
                                uiKeyTimeCnt=0; //????????????,??????
                        else if(ucKeyLock==0)  //?????,???????
                                        uiKeyTimeCnt++;  //
                                                uiKeyTimeCnt=0;
                                                ucKeySec=5;  //??5??
                                                uiKeyTimeCnt=0;
                                                ucKeySec=6;  //??6??
                                                uiKeyTimeCnt=0;
                                                ucKeySec=7;  //??7??
                                                uiKeyTimeCnt=0;
                                                ucKeySec=8;  //??8??
                        break;
                case 7:   //????????????
                        key_dr1=1;
                        key_dr2=1;
                        key_dr3=0;
                        key_dr4=1;
                        key_dr5=1;
                        key_dr6=1;
                        break;
                case 8:     //???????????????????,????????????????
                        uiKeyTimeCnt++;
                        if(uiKeyTimeCnt>1)
                                uiKeyTimeCnt=0;
                        break;
                case 9:
                                                uiKeyTimeCnt=0;
                                                ucKeySec=9;  //??9??
                                                uiKeyTimeCnt=0;
                                                ucKeySec=10;  //??10??
                                                uiKeyTimeCnt=0;
                                                ucKeySec=11;  //??11??
                                        uiKeyTimeCnt++;          //
                                                uiKeyTimeCnt=0;
                                                ucKeyLock=1;        //
                                                ucKeySec=12;          //
                        break;
                case 10:   //
                        key_dr1=1;
                        key_dr2=1;
                        key_dr3=1;
                        key_dr4=0;
                        key_dr5=1;
                        key_dr6=1;
                        uiKeyTimeCnt=0;  //
                        ucKeyStep++;     //
                        break;
                case 11:     //
                        uiKeyTimeCnt++;
                        if(uiKeyTimeCnt>1)
                                uiKeyTimeCnt=0;
                        break;
                case 12:
                                ucKeyStep++;  //
                                ucKeyLock=0;  //
                                uiKeyTimeCnt=0; //
                                        uiKeyTimeCnt++;  //
                                                uiKeyTimeCnt=0;
                                                ucKeyLock=1;//
                                                ucKeySec=13;  //
                                                uiKeyTimeCnt=0;
                                                ucKeySec=14;  //??14??
                                                uiKeyTimeCnt=0;
                                                ucKeySec=15;  //??15??
                                                uiKeyTimeCnt=0;
                                                ucKeySec=16;  //??16??
                        break;
                case 13:   //????????????
                        key_dr1=1;
                        key_dr2=1;
                        key_dr3=1;
                        key_dr4=1;
                        key_dr5=0;
                        key_dr6=1;
                        break;
                case 14:     //???????????????????,????????????????
                        uiKeyTimeCnt++;
                        if(uiKeyTimeCnt>1)
                                uiKeyTimeCnt=0;
                        break;
                case 15:
                                ucKeyStep++;  //????????,??????,??????
                                                uiKeyTimeCnt=0;
                                                ucKeySec=17;  //??17??
                                                uiKeyTimeCnt=0;
                                                ucKeySec=18;  //??18??
                                                uiKeyTimeCnt=0;
                                                ucKeySec=19;  //??19??
                                                uiKeyTimeCnt=0;
                                                ucKeySec=20;  //??20??
                        break;
                case 16:   //????????????
                        key_dr1=1;
                        key_dr2=1;
                        key_dr3=1;
                        key_dr4=1;
                        key_dr5=1;
                        key_dr6=0;
                        break;
                case 17:     //???????????????????,????????????????
                        uiKeyTimeCnt++;
                        if(uiKeyTimeCnt>1)
                                uiKeyTimeCnt=0;
                        break;
                case 18:
                                ucKeyStep=1;  //????????,??????,??????
                                                uiKeyTimeCnt=0;
                                                ucKeySec=21;  //??21??
                                                uiKeyTimeCnt=0;
                                                ucKeySec=22;  //??22??
                                                uiKeyTimeCnt=0;
                                                ucKeySec=23;  //??23??
                                                uiKeyTimeCnt=0;
                                                ucKeySec=24;  //??24??
                        break;
        //return ucKeySec;
void key_service() //
    u8         ucKeyThird = 0;
        u8  temp = 0;
        LED0 = !LED0;
    switch(ucKeySec) //????????
        case 1:// 1??
            printf("Ò»ºÅ¼ü");
//            SoftReset();
            //uiVoiceCnt=const_voice_short; //??????,??????
            ucKeySec=0;  //???????????,??????,??????
            break;
        case 2:// 2??
            AssitButton();//????????
            ucKeyThird = 1;
            while(ucKeyThird)
                switch(ucKeySec)
                    case 1:
                        //SoftReset();
                        ucKeySec=0;
                        ucKeyThird = 0;
                        break;
                    case 2:
                        AssitButton();
                        ucKeySec=0;
                        ucKeyThird = 0;
                        break;
                    case 3:
                        prepare();
                        ucKeyThird = 0;
                        break;
                    case 4:
                        CediButton();
                        ucKeyThird = 0;
                        break;
                    case 10:
                        printf("The No.10 Button");
                        PointButton();
                        ucKeySec=0;
                        ucKeyThird = 0;
                        break;
                    case 11:
                        PointButton();
                        ucKeySec=0;
                        ucKeyThird = 0;
                        break;
                    case 15:
                        printf("The No.15 Button");
                        StatusButton();
                        ucKeySec=0;
                        ucKeyThird = 0;
                        break;
                    case 24:
                        ucKeyThird = 1;
                        break;
            break;
        case 3:// 3??
            ++temp;
            printf("The No.3 Button");
            prepare();
            //Init1();
            break;
        case 4:// 4??
            --temp;
            printf("Ëĺżü");
            CediButton();
            break;
        case 5:// 5??
            printf("ÎåºÅ¼ü");
            temp++;
            if(1==temp)
               Down();
            if(2==temp)
                Up();
                temp = 0;
            break;
        case 6:// 6??
            printf("ÁùºÅ¼ü");
            FrontButton();
            break;
        case 7:// 7??
            printf("Æߺżü");
            EditorButton();
            break;
        case 8:// 8??
            printf("°ËºÅ¼ü");
            SendButton();
            break;
        case 9:// 9??
            printf("¾ÅºÅ¼ü");
            ClockButton();
            break;
        case 10:// 10??
            printf("Ê®ºÅ¼ü");
            ConfigeButton();
            break;
        case 11:// 11??
            printf("ʮһºÅ¼ü");
            break;
        case 12:// 12??
            printf("Ê®¶þºÅ¼ü\n");
            break;
        case 13:// 13??
            printf("Ê®ÈýºÅ¼ü\n");
            break;
        case 14:// 14??
            printf("Ê®Ëĺżü\n");
            break;
        case 15:// 15??
            InitInterface();
            printf("Ê®ÎåºÅ¼ü\n");
            break;
        case 16:// 16??
            printf("Ê®ÁùºÅ¼ü\n");
            break;
        case 17:// 17??
            printf("The No.17 Button\n");
            break;
        case 18:// 18??
            printf("The No.18 Button\n");
            break;
        case 19:// 19??
            printf("The No.19 Button\n");
            break;
        case 20:// 20??
            InitInterface();
            printf("The No.20 Button\n");
            break;
        case 21:// 21??
            printf("The No.21 Button\n");
            //LCD();
            break;
        case 22:// 22??
            printf("The No.22 Button\n");
            break;
        case 23:// 23??
            printf("The No.23 Button\n");
            //LCD1();
            break;
        case 24:// 24??
            //LCD2();
            printf("The No.24 Button\n");
            break;
发表于 2014-5-8 12:41:42 | 显示全部楼层
一步步硬件调试,用万用表测一下输出,慢慢找出问题
发表于 2014-5-8 12:44:43 | 显示全部楼层
先将代码简化,与按键无关的注释掉,然后DEBUG慢慢找
GMT+8, 2024-11-23 13:34 , Processed in 0.033933 second(s), 24 queries , Gzip On.
