查看: 14100|回复: 1
SPI flash 问题求解?
发表于 2015-4-14 19:23:22 | 显示全部楼层 |阅读模式
我向spi  flash里面写入汉字字库,但是取不出来我也不知道烧成功了没有。求大神解答啊??
#include "stm32f10x_conf.h"
#include "bsp_ili9341_lcd.h"
#include "bsp_led.h"
//#include "tupian.h"
#include "spi_flash.h"
#include "bsp_usart1.h"
#include "stdio.h"
void Delay(uint32_t N)
        int i;
        for(i=0;i<N;i--);
//&#214;&#216;&#182;¨&#207;òoˉêy usart1
int fputc(int ch, FILE *f)
                /* ?????????USART1 */
                USART_SendData(USART1, (uint8_t) ch);
                while (USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
                USART_ClearFlag( USART1, USART_FLAG_TXE);
                return (ch);
///???c???scanf?USART1
int fgetc(FILE *f)
                /* ????1???? */
                while (USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET);
                USART_ClearFlag(USART1,USART_FLAG_RXNE);
                return (int)USART_ReceiveData(USART1);
void GetGBKCode(unsigned char* pBuffer,unsigned char * c)
   unsigned char High8bit,Low8bit;
   High8bit=*c;     /* è&#161;&#184;&#223;8&#206;&#187;êy&#190;Y */
   Low8bit=*(c+1);  /* è&#161;μí8&#206;&#187;êy&#190;Y */
        SPI_FLASH_PageWrite(pBuffer,(94*(High8bit-0xa0-1)+(Low8bit-0xa0-1))*32,32);
// SPI_FLASH_BufferWrite(pBuffer,((High8bit-0xb0)*94+Low8bit-0xa1)*64,64);
         printf("\r\n ′óW25x16 SPI FLASH&#182;á3&#246;μ&#196;êy&#190;Yê&#199;: %s",pBuffer);
void PutChinese(uint16_t Xpos,uint16_t Ypos,uint8_t *str,uint16_t Color,uint16_t bkColor)
        uint8_t i=0,j=0;
        uint8_t buffer[32];
        GetGBKCode(buffer,str);  /* è&#161;×&#214;&#196;£êy&#190;Y */
        for (i=0;i<16;i++)
                for(j=0;j<8;j++)
                        if ( (buffer[i*2] >> 7-j) & 0x01 == 0x01)
                                LCD_SetPoint(Xpos+i,Ypos+j,Color);  /* ×&#214;·&#251;&#209;&#213;é&#171; */
                                LCD_SetPoint(Xpos+i,Ypos+j,bkColor);  /* ±3&#190;°&#209;&#213;é&#171; */
                        if ( (buffer[i*2+1] >> 7-j) & 0x01 == 0x01)
                                LCD_SetPoint(Xpos+i,Ypos+j+8,Color);  /* ×&#214;·&#251;&#209;&#213;é&#171; */
                                LCD_SetPoint(Xpos+i,Ypos+j+8,bkColor);  /* ±3&#190;°&#209;&#213;é&#171; */
void GUI_Chinese(uint16_t Xpos, uint16_t Ypos, uint8_t *str,uint16_t Color, uint16_t bkColor)
  do
    PutChinese(Xpos,Ypos,str++,Color,bkColor);
        str++;
   if (Ypos<304)
      Ypos+=16;
    else if (Xpos<224)
      Ypos=0;
      Xpos+=16;
      Xpos=0;
      Ypos=0;
  while(*str!=0);
int main()
        // int i,num;
   LCD_Init();
         Lcd_GramScan(1);
         LED_GPIO_Config();
         LCD_Clear(0,0,240,320,BLUE);
         USART1_Config();
         NVIC_Config();
   SPI_GPIO_Config();
        // SPI_flash_Sectorall();
         LED1_ON;
         LED2_ON;
         LED3_ON;
   printf("3ìDò&#213;y&#212;ú&#212;&#203;DD");
         GUI_Chinese(20,20,"&#206;òê&#199;",YELLOW,BLACK);
 楼主| 发表于 2015-4-14 19:24:06 | 显示全部楼层
不知道我的注释怎么都没有了。
GMT+8, 2025-1-6 19:19 , Processed in 0.030059 second(s), 23 queries , Gzip On.
