查看: 19447|回复: 1
GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource0)语句不懂求解
发表于 2015-7-15 15:53:00 | 显示全部楼层 |阅读模式
请问下面这段程序中  GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource0)这条语句是干什么用的,为啥会出下在这里,大神求解,麻烦说详细点
  * @file    bsp_exti.c
  * @author  fire
  * @version V1.0
  * @date    2013-xx-xx
  * @brief   I/OÏßÖD¶Ïó|óÃbsp
  * @attention
  * êμÑéƽì¨:ò°»e iSO STM32 ¿a·¢°å
  * ÂÛì3    :http://www.firebbs.cn
  * ìÔ±|    :http://firestm32.taobao.com
#include "bsp_exti.h"
  * @brief  ÅäÖÃǶì×Ïòá¿ÖD¶Ï¿ØÖÆÆ÷NVIC
  * @param  ÎT
  * @retval ÎT
static void NVIC_Configuration(void)
  /* Configure one bit for preemption priority */
  /* ÅäÖÃÖD¶ÏÔ′ */
  NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn;
  * @brief  ÅäÖà PA0 ÎaÏßÖD¶Ï¿ú£¬2¢éèÖÃÖD¶ÏóÅÏ輶
  * @param  ÎT
  * @retval ÎT
void EXTI_PA0_Config(void)
        EXTI_InitTypeDef EXTI_InitStructure;
        /* config the extiline clock and AFIO clock */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO,ENABLE);
        /* config the NVIC */
        NVIC_Configuration();
        /* EXTI line gpio config*/
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;         // éÏà-êäèë
        /* EXTI line mode config */
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource0);
  EXTI_InitStructure.EXTI_Line = EXTI_Line0;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; //ϽμÑØÖD¶Ï
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
发表于 2015-7-15 17:59:27 | 显示全部楼层
按住F12,查看该函数原型,这个函数的作用是:Selects the GPIO pin used as EXTI Line
翻译过来就是配置IO口为中断线,当IO上出现下降沿和上升沿时,可以产生IO中断。
STM32 每一个 IO 都可以配置为 EXTI LINE 模式。
  1. /**
  2.   * @brief  Selects the GPIO pin used as EXTI Line.
  3.   * @param  GPIO_PortSource: selects the GPIO port to be used as source for EXTI lines.
  4.   *   This parameter can be GPIO_PortSourceGPIOx where x can be (A..G).
  5.   * @param  GPIO_PinSource: specifies the EXTI line to be configured.
  6.   *   This parameter can be GPIO_PinSourcex where x can be (0..15).
  7.   * @retval None
  8.   */
  9. void GPIO_EXTILineConfig(uint8_t GPIO_PortSource, uint8_t GPIO_PinSource)
  10. {
  11.   uint32_t tmp = 0x00;
  12.   /* Check the parameters */
  13.   assert_param(IS_GPIO_EXTI_PORT_SOURCE(GPIO_PortSource));
  14.   assert_param(IS_GPIO_PIN_SOURCE(GPIO_PinSource));
  15.
  16.   tmp = ((uint32_t)0x0F) << (0x04 * (GPIO_PinSource & (uint8_t)0x03));
  17.   AFIO->EXTICR[GPIO_PinSource >> 0x02] &= ~tmp;
  18.   AFIO->EXTICR[GPIO_PinSource >> 0x02] |= (((uint32_t)GPIO_PortSource) << (0x04 * (GPIO_PinSource & (uint8_t)0x03)));
  19. }
GMT+8, 2025-1-10 07:10 , Processed in 0.053609 second(s), 23 queries , Gzip On.
