查看: 11888|回复: 3
按键中断改变led求大神帮助 看下我的简单代码
发表于 2016-7-26 11:21:36 | 显示全部楼层 |阅读模式
看到论坛,如鱼得水。我想用PB12(按键)控制PC0(LED)好几天都没有成功求大神看看哪里错了啊
#include"stm32f10x_lib.h"
#include<stdio.h>
void RCC_Configuration(void);
void GPIO_Configuration(void);
void EXTI_Configuration(void);
void NVIC_Configuration(void);
        RCC_Configuration();
        GPIO_Configuration();
        EXTI_Configuration();
        NVIC_Configuration();
        while(1);
        ErrorStatus HSEStartUpStatus;
          RCC_DeInit();
          RCC_HSEConfig(RCC_HSE_ON);
          HSEStartUpStatus = RCC_WaitForHSEStartUp();
          if(HSEStartUpStatus == SUCCESS)
            RCC_HCLKConfig(RCC_SYSCLK_Div1);
            RCC_PCLK2Config(RCC_HCLK_Div1);
            RCC_PCLK1Config(RCC_HCLK_Div2);
            FLASH_SetLatency(FLASH_Latency_2);
            FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
            RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
            RCC_PLLCmd(ENABLE);
            while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
            RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
            while(RCC_GetSYSCLKSource() != 0x08);
          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);
                RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);        //ê1&#196;üAPB2íaéèμ&#196;GPIOCμ&#196;ê±&#214;ó
                RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP ;
        GPIO_ResetBits(GPIOC,GPIO_Pin_0);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU ;
        EXTI_InitTypeDef EXTI_InitStructure;
        EXTI_DeInit();
        EXTI_ClearITPendingBit(EXTI_Line12);
        GPIO_EXTILineConfig(GPIO_PortSourceGPIOB, GPIO_PinSource12);
        EXTI_InitStructure.EXTI_Line = EXTI_Line12;
        EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
        EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising_Falling;
        EXTI_InitStructure.EXTI_LineCmd = ENABLE;
        EXTI_Init(&EXTI_InitStructure);
        NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQChannel;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority =0;
---------------------------这是中断--------------------------------------
void EXTI15_10_IRQHandler(void)
        if(EXTI_GetFlagStatus(EXTI_Line12)!=RESET)
                GPIO_SetBits(GPIOC,GPIO_Pin_0);
 楼主| 发表于 2016-7-26 11:23:18 | 显示全部楼层
求大神指点啊
发表于 2016-7-26 11:51:46 | 显示全部楼层
这个不是直接按例程来改就可以了吗。。完全一样的
 楼主| 发表于 2016-7-26 12:16:24 来自手机 | 显示全部楼层
我这个按别人视频写的。不知道哪里错了
GMT+8, 2024-11-24 13:27 , Processed in 0.033081 second(s), 26 queries , Gzip On.
